supercharger question
i have a stillen v2 3.33 supercharger currently installed on my car with the cartech fmu i was gonna install my z32 maf, 555 injectors and walbro fuel pump and the jwt ecu
could i take the cartech out and leave it without no fmu ?
would i have to do anything else?
The JWT ecu will be tuned based on oem fuel pressure, so if your Walbro fuel pump is giving you higher than oem fuel pressure, you will need an adjustable fpr to bring it back down to 34 psi at idle. With larger injectors, higher than normal fuel pressure will result in a rich idle and possible flooding at startup.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
