Need Blueprint of a 4th Gen turbo kit.
Old Feb 15, 2005 | 04:34 PM
Turk's Avatar
Hey, i was looking around and figured that i wana build my own turbo with a little help from the org and Alex. Well make the long story short i wana get an idea of the pipes diameter, length, and degrees of bend etc.... I have a blue print based on this pic you see. Welding will be done. I basically need a write on what i stated. Pics and general outline would be appriciated. BTW Its a 5 speed 1995 Maxima. thanks again.
Old Feb 15, 2005 | 06:27 PM
joosdawg's Avatar
buy some bends and pipes and flanges oil lines fittings random nuts and bolts some fuel nessesities and call it a day. personally i wish i could just make an up-pipe downpipe oil lines and charge piping and be done why does it have to be more complicated?
Old Feb 15, 2005 | 07:00 PM
FriscoMaxima's Avatar
I am, planning to use this same setup you have a picture of there, but i will modify it a little... You see that red pipe that carries exhaust gasses from headers? it seems kind of long and will generate more turbo lag. what i want to do is reverse the rear heared pipe so that both right and left bank of cylinders would join into one pipe directly underneath the engine and from there go back up into the engine compartment. I will go try to modify that pic to show what i want to do...
Old Feb 15, 2005 | 07:04 PM
joosdawg's Avatar
you cant do that...its shaped like that for a reason, GROUND CLEARANCE. think about it and if you have to, look under your engine to see that it would be hitting every drivway good thinking though
Old Feb 15, 2005 | 07:20 PM
there... see, the joint will be pointing towards the driver's wheel and the pipe will go straight up to where the battery usually is...
Old Feb 15, 2005 | 08:14 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
thats where the tranny is
Old Feb 15, 2005 | 08:24 PM
Turk's Avatar
This the thing, engine moves constantly that why we have flex section. The drawing you have need a flex section welded on or it will snap and damage pipes. Good brainstorming.
This Pipe would work but, i am trying to minimize turbo lag. Getting evey HP as posible.
Any ideas would be helpful.
BTW when we get measurements would anyone be intrested purchasing custom made pipes.
Old Feb 15, 2005 | 08:36 PM
Turk's Avatar
BTW, If anyone is intrested and would like to help on the project please contact me. Only if you serious. I can get my hands on pipes, i know machine shops, and also i can get welding equipment. I live in PA. NJ, NY,MD, PA, CT people are welcome to take a shot at this. Trying to get many people on this project, meaning cheaper for each person.
Old Feb 15, 2005 | 08:40 PM
if there was just a pipe kit available, i would love to get my hands on it, especially the segment that goes from a turbo to the cat. if someone would be able to fabricate each pipe separately, it would be awesome....
Old Feb 15, 2005 | 08:48 PM
Turk's Avatar
We are in the process of fabricating complete setup pipes. Will keep you informed.
Old Feb 15, 2005 | 08:50 PM
Requin6's Avatar
yeah you are going to have a problem getting around the tranny with the pipe feeding in that direction.
Old Feb 15, 2005 | 08:57 PM
JeffesonM's Avatar
living out of a maxima...
anybody know who did that autocad-type picture?
Old Feb 15, 2005 | 09:00 PM
Turk's Avatar
Got it off the this site. I shows you who has that setup.
Click Here...
Old Feb 15, 2005 | 09:16 PM
I am still working on the design, but eventually I WILL make it the way i want. My current design will prolly have to be modified, but no kit was made from the first trial...
Old Feb 15, 2005 | 09:22 PM
Magikone69's Avatar
id love to have just a piping kit, that way each persons kit is more of a custom kit. i know its early but any idea on pricing. is this strictly for 5spd
Old Feb 15, 2005 | 09:31 PM
Turk's Avatar
We are currently working on a 5 speed. I know later down the road we might have an auto version.
Old Feb 15, 2005 | 09:38 PM
urmab's Avatar
Im Alex and ill be working with tman on this project, as far as pricing is concern we are not sure untill we get the first prototype done .
Alex
slimer's Avatar
on_alert made the original cad. he did it for a school engineering project.
Old Feb 15, 2005 | 10:05 PM
Broaner's Avatar
2060lbs and falling...
What is so wrong with the tried and true reverse Y?
Old Feb 15, 2005 | 10:10 PM
look at the length of that thing... there's a lotta air that needs to be compressed before the car starts boosting. that is why the perfect place for a turbo is on a header...
Old Feb 15, 2005 | 10:19 PM
Broaner's Avatar
I said REVERSE Y. Not the one in the CAD.
Old Feb 15, 2005 | 10:22 PM
urmab's Avatar
well the clearence issue this is removing one fan but we are concidering making both designs
Turk's Avatar
Something like this i suppose?
Old Feb 15, 2005 | 10:24 PM
Royal_T's Avatar
You just bet me to that pic, I know most people includeing me are routing the pipe in front of the engine
Broaner's Avatar
Yes. The fan in question can be removed and a push fan can be placed on the other side.
Old Feb 15, 2005 | 10:26 PM
Royal_T's Avatar
I think there is a way to keep the factory fans
Old Feb 15, 2005 | 10:32 PM
that piture is VERY close to what i want. Who made it for you?
Old Feb 15, 2005 | 10:35 PM
Turk's Avatar
Got it off the website. We are trying to get a best setup to work, without the hassle of relocating. Basically Plug and play.
Old Feb 15, 2005 | 10:47 PM
just one noob question.... That wastegate right there... is it manually adjustable? Do i need a boost controller to run with it?
Old Feb 15, 2005 | 11:52 PM
I30tMikeD's Avatar
I now have the piping that was made from that CAD pic. On_Alert desinged and fabricated it. Had it installed for a short time. Sold it to Nealoc187 but never installed it. Sold it to me and it will be on my car shortly.
Here is a better pic of the pipes I recently took.
http://img.photobucket.com/albums/v1...d/112_1266.jpg
Old Feb 15, 2005 | 11:58 PM
Royal_T's Avatar
I think it is time to get thoughs pipes painted with Jet Hot or something.
Old Feb 16, 2005 | 12:07 AM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
check my car domain site for my pipes. i kept my fans and i dont have that u bend in mine either
Old Feb 16, 2005 | 12:15 AM
I30tMikeD's Avatar
Don't worry, I am droping them off to get ceramic coated in a statin silver color tomorrow morning.
Old Feb 16, 2005 | 07:20 AM
Shadow's Avatar
And with a properly sized turbo, lag is still minimal. With the Uturn pipe like that, I'm still seeing full boost by ~3200 on a pretty big turbo. The other setup we built used a smaller turbo and he saw full boost at ~2800. In theory, yes of course a shorter pipe is better, but in reality it's not as big of a difference as you think.
After I get my current setup tuned at 12psi, I'll probably rework all the pipes to the reverse Y setup but with the turbo on the passenger side like Hal. It would require new fans and a custom radiator, but I think that's a worthwhile sacrifice to essentially eliminate about 6 ft. of feed and intercooler piping.
Old Feb 16, 2005 | 10:12 AM
JeffesonM's Avatar
I believe on_alert isn't around any more... anybody know what program was used to make the drawing? Was it just AutoCAD?
Old Feb 16, 2005 | 10:21 AM
Does anyone have pictures of Hal's setup?
Old Feb 16, 2005 | 02:12 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What psi is "full boost" and for which turbos again?
Old Feb 16, 2005 | 03:47 PM
Nealoc187's Avatar
SLOW
It was autocad I believe. He posts here every once in a while.
Old Feb 16, 2005 | 06:44 PM
lex4style's Avatar
let us know when u guys start selling them...if u make a setup for the auto. Count me in.
Old Feb 16, 2005 | 07:10 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Pick a thread.... this one, the one in the fourth gen forum, or a new thread...
There is going to be to much cross posting. Pick what you wana do and let me know in 24 hrs.
