Question about adjusting BOV
Old Feb 21, 2005 | 09:57 AM
MaXtUneD's Avatar
I got a question, maybe with a simple answer, but I just want to be safe and sure..
I have the HKS SSQ BOV, what if I tighten the bolt on the back or loosen it, will that affect vacuum or boost pressure?
If not, tightening it would give me what kind of sound, and loosening it would give me what typ of sound?
Thanks guys..
Old Feb 21, 2005 | 10:47 AM
95turbo gxe's Avatar
I think if you tighten it gets louder. By the way if you cant figure it out you could just give it to me
Old Feb 21, 2005 | 08:26 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
if you loosen it too much - you may vent @ idle.... meaning that you may lose metered air depending on your setup...i.e. running rich
Old Feb 21, 2005 | 10:21 PM
vortechpower's Avatar
I don't think the hks bov leaks at all no matter where it is set. I have seen 1/2 psi gains by tightening the hks on turbos
I don't think the hks bov leaks at all no matter where it is set. I have seen 1/2 psi gains by tightening the hks on turbos compared to other bov's
Old Feb 22, 2005 | 06:52 AM
cardana24's Avatar
Blown
I thought you were not suposed to adjust the screw on the SSQV? I am just hoping on the thread because I am interested as well.
Old Feb 22, 2005 | 08:20 AM
That is what the screw is there for?? Adjustments..
Old Feb 22, 2005 | 09:58 AM
I30tMikeD's Avatar
I have read from HKS themselves to not adjust that screw becasue over adjustment can result in failure of the inner diaphram.
You don't tighten and loosen it for sound.
Old Feb 22, 2005 | 01:58 PM
MaXtUneD's Avatar
Oh ok..I'm better off not messing with it..MAF on charged side...if that matters about air venting out but with the replies saying that it doesn't at all..
Old Feb 23, 2005 | 05:16 AM
cardana24's Avatar
Blown
sorry to go off topic, but are you coming to the track on march 6th? D.C. local is having a track meet at MIR.
Old Feb 23, 2005 | 08:41 AM
MaXtUneD's Avatar
No, I won't be able to make it to the track because I will be out of town...besides, my car is not ready for the track yet..Still got to do some other things to it...But I will be at the woodbridge meet March 5 which is a Saturday. Its at a commuter lot off the exit of Ocoquan(Spelling)....7pm-11pm...
Old Feb 23, 2005 | 11:38 PM
Why can't you adjust the bov, that is what it is there for?
Old Feb 24, 2005 | 03:31 AM
I have seen your setup beeing built. I had a small say in that set up. Customized your turbo off the sc setup in some aspects. I would def say adjust your bov. Your car look like such the sleeper!
Old Feb 24, 2005 | 07:23 AM
MaXtUneD's Avatar
well..some say it will ruin the inner diaphram..some say i will lose metered air which will cause me to go rich...
Old Feb 24, 2005 | 08:17 AM
Stephen Max's Avatar
Looking at your sigpic, it looks like the maf is after the bov. If that is the case, you won't lose metered air through the bov.
Old Feb 24, 2005 | 02:30 PM
Morfeus17's Avatar
From my understanding.. The more boost your running, the tighter you should adjust your BOV. The less boost your running, the looser the BOV should be. Its all a matter of keeping the compressed air from bleeding away under boost while the plates are open. And Bleeding it off when the plates are closed. If your running 12 PSI or more of boost... The BOV should not be loose, chances are you would bleed off compressed air...
Best bet, I would keep the adjustment mid center...
aw11power
Oct 10, 2021 04:57 AM
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Socalstillen
Sep 26, 2015 12:01 PM
