Question about the Emanage???
Old Feb 23, 2005 | 12:30 AM
96_vqmax's Avatar
What parts do I need for my turbo?Here's the list and if I miss out something else pls let me know,thanx!
Powerful E-manage Main Unit and Main Harness
Additonal injection harness
Ignition harness
E-manage Support Tool (Software and Connection cable)
Greddy Pressure Sensor and Pressure Sensor Harness
E01 programmer
Old Feb 23, 2005 | 11:07 AM
stephenlc's Avatar
you dont need the E01, just a laptop. And the additional injection harness is useless
Old Feb 23, 2005 | 11:19 AM
chris'smax's Avatar
If he plans on running larger injectors he will need it
Old Feb 23, 2005 | 11:22 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
I'm running 555cc's without the injector harness fine
Old Feb 23, 2005 | 11:24 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
that is incorrect...with bigger injectors like 500cc+ you should only have to subtract fuel...that can all be done through the airflow adj map...which can be operated W/O the harness. the harness is only needed to add fuel in the addj. map and for datalogging
Old Feb 23, 2005 | 11:56 AM
chris'smax's Avatar
i stand corrected . Well i'm glad you guys told me before i ordered mine today. So with 510cc injectors at 12psi i wouldn't need the harness.
Old Feb 23, 2005 | 12:12 PM
huyqvu's Avatar
i havent gotten mine yet, but ive been told emanage with boost controller only goes up to 14lbs of boost? yay nay?
Old Feb 23, 2005 | 12:50 PM
DA-MAX's Avatar
thats wrong...we hit 16lbs in Redmax's car the other day
Old Feb 23, 2005 | 12:51 PM
DA-MAX's Avatar
personally I think its worth it(its on $30 or so) for datalogging...the ability to datalog IDCs is very helpful IMO, although with 510s you probably won't be anywhere near 80%
Old Feb 23, 2005 | 12:56 PM
sx7r's Avatar
if you want to monitor injector pulse width, you'll need the harness. otherwise you can be like seximagtr - cup your ears and just listen real carefully to tell how long each injector stays open for.
Old Feb 23, 2005 | 01:55 PM
turbomax97's Avatar
ehehhee don't be jealous thomas
Old Feb 23, 2005 | 02:05 PM
sx7r's Avatar
bored? i see you're forum hopping, lol
Old Feb 23, 2005 | 08:23 PM
96_vqmax's Avatar
So I need all this right?
Ignition harness
How about this Greddy Pressure Sensor and Pressure Sensor Harness?Do I need this if I go with the Z32 MAF?Or what else do I need to make this Z32 MAF work on the car?Thanx!
Old Feb 23, 2005 | 08:25 PM
96_vqmax's Avatar
Also what many psi does the 370cc max out(working 100 cycle)?
Old Feb 23, 2005 | 10:04 PM
chris'smax's Avatar
I think some people who run the 2.87 say they are above 80% DC
Old Feb 23, 2005 | 11:10 PM
96_vqmax's Avatar
So how many psi does the 2.87 pully make?
Old Feb 24, 2005 | 05:25 AM
chris'smax's Avatar
it depends anywhere from 12-13.5 psi
Old Feb 24, 2005 | 06:30 AM
Blu's Avatar
Blu
the tits
come on man all this stuff is in the stickies...370's max out in the 330-340whp range...
Old May 16, 2005 | 07:07 PM
amomaxima's Avatar
is anyone using the emanage system and not going turbo i want to get one but i am not sure if it is worth it since i dont plan of turboing the car have any ideas
Old May 16, 2005 | 08:25 PM
DA-MAX's Avatar
chrismax is sc'd with Emanage. its a very helpful tool with ANY form of FI. if you mean using it n/a, than its not necessary unless you are making serious power all motor
Old May 17, 2005 | 06:11 AM
Stephen Max's Avatar
I have gotten 14.5 psi on a cold day and with a clean filter, with a V1 blower.
Old May 18, 2005 | 09:21 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
So is LatinMax.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
