Setting for Emanage?
Old Mar 5, 2005 | 09:40 AM
chris'smax's Avatar
The surgery on the max has begun. Right now i am installing the emanage and i need to know what are the rotary settings on the Emanage? I searched through about 50 pages and can't find it.
Chris
Old Mar 5, 2005 | 10:45 PM
MAXimumHP's Avatar
Not sure if 5th gens are the same, but the fourth gens use rotary settings 7-0-1.
Old Mar 5, 2005 | 11:09 PM
Redmax's Avatar
Redlinemax Owner
never done the install on a 5th gn, but I'd assume for the stock MAF its still 7-0-1...all these settings are is to identify the MAF and vehicle type....so I'd assume its the same. but check on the emanage forum or mailing list
(DA-MAX, logged in on coreys sn)
Old Mar 6, 2005 | 12:54 AM
LatinMax's Avatar
701 is correct!
Old Mar 7, 2005 | 09:37 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Per studman...7-0-B...if you have the latest 1.39 firmware version. At least on VQ35s that have very similar MAFs.
Old Mar 7, 2005 | 09:44 AM
chris'smax's Avatar
Do you have to update to the latest version or is it dependant on when the support tool was purchased?
Old Mar 7, 2005 | 09:55 AM
IceY2K1's Avatar
You should, especially if you plan on using the timing harness IIRC.
Firmware of main unit isn't linked to a specific support tool version as far as I know, however I'd always keep up with the latest since it seems to eliminate bugs/quirks people have.
Just BE CAREFUL uploading new firmware to the main unit, MANY many people corrupt theirs and have issues. Find the firmware update directions that are on my350z.com or probably on the yahoo group.
Old Mar 7, 2005 | 11:01 AM
Redmax's Avatar
Redlinemax Owner
Actually Ice, like microsoft, some of the firmwareupgrades have caused other problems with the units so it is best to stay 1 version back let other people find the bugs!!!
Old Mar 7, 2005 | 11:03 AM
IceY2K1's Avatar
v1.39 seems to have the least amount of bugs and keeps from burning up the coils w/diodes as far as I've read.
Heard any different?
Old Mar 9, 2005 | 03:24 PM
IceY2K1's Avatar
Chris,
How's the eManage tuning going?
Old Mar 9, 2005 | 05:32 PM
chris'smax's Avatar
The emanage is hooked up just waiting on my support tool to be delivered.
Btw how in the hell do you remove the fuel rail to install the new injectors? Any tips on this install?
Old Mar 9, 2005 | 07:31 PM
IceY2K1's Avatar
If you have a factory service manual, check out EC section pages 51-52, if not, for $20 go download yourself one.
You could really help out the .org by taking pictures and doing a writeup of your process with the injector/eManage install. I know more and more people will be following in your footsteps incase you have the time/energy to followup.
Old Mar 10, 2005 | 07:37 AM
chris'smax's Avatar
how much do the FSM's cost. Cant you get them at the nissan dealership. I will provide pics and try and do a write up. It may not be great because mostly when i do things it involves alot of cussing yanking and just ripping things out . I will deff follow up with dyno graphs and reviews
Old Mar 10, 2005 | 07:43 AM
IceY2K1's Avatar
$20...for the electronic version you download.
http://forums.maxima.org/showthread....ighlight=cheap
Old Mar 10, 2005 | 10:27 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
the pdf version is awesome!
Old Mar 10, 2005 | 10:29 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
damn $20......screw that
Old Mar 10, 2005 | 10:38 AM
IceY2K1's Avatar
Cheap SOBs....$20 is a friggen steal and if people abuse it like a certain website we know, it will get shut down.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
