stupid question from a noob
Old Mar 24, 2005 | 08:10 PM
Slow95VQ's Avatar
hey guys it's me again with another noobie ? Well here is my situation: I am planning on doing an oovi swap or mevi swap(not sure which one yet) and getting a retuned ecu from either ts/jwt, but i also plan on doing a simple turbo setup with no intercooler pushing maybe at max about 6psi with a t3/t04e. My real question is should i do the IM swap but wait to retune the ecu for a turbo application?(i won't have the money to do everything at once) and another question that i have is what would i need for a simple turbo setup besides a bov, manifold, wastegate, turbo,fpr, and a fuel pump.
Old Mar 24, 2005 | 09:28 PM
I30tMikeD's Avatar
Don't do a turbo without an intercooler
TS can't really do a boosted program, they could set your AF ratio and timing but they don't know how to adjust for larger injectors or MAF
If money is a concern with doing everything at once, I suggest doing the turbo the right way (intercooler) and not even messing with the manifold right now.
You have the basic parts listed for a turbo set up but there is much, much more. Down pipe, FMU or some type of fuel management, all the oil lines and fittings, couplers, T-bolts....what about the tranny? Clutch? Expect to spend at least $2,500 or so. Can you do the install your self?
Also, 6psi is going to most likely need larger injectors. I have mine maxed out with 5psi.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
