pintel caps
Old Mar 25, 2005 | 09:52 AM
sleeper's Avatar
pintel caps
what is the purpose of a pintel cap ?
Old Mar 25, 2005 | 11:52 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Man, I have been trying to find that out..
call RC engineering
edit... owns me
http://www.witchhunter.com/injectcut1.htm
Old Mar 25, 2005 | 01:01 PM
sleeper's Avatar
answer
rc says the pintel caps are there to protect the injector, they shouldn't bother performance. they say you should replace them if they are broken because the injectors are costly. they perform this service on a machine for $1.25 each. they said to specify "REPLACE PINTEL CAPS ONLY", when you send them in, or they will also perform cleaning, which is $28.50 each.
Old Mar 25, 2005 | 01:52 PM
I30tMikeD's Avatar
in addition, when the car is turned off there will usually be one small drop of fuel on the end of the injector. The pintal cap will direct thaT drop of fuel away from the opening of the injector helping to reduce clogging. With out a pintal cap the enzymes, or what have you, will dry on the end.
Old Mar 26, 2005 | 04:14 AM
superdave2
In some applictions, the pintle cap just protects the pintle and wicks away fuel droplets to minimize depositing (like Mike said). In this case a missing or broken pintle cap is no big deal.
In other applications (such as 4th gen maxima sidefeeds) the pintle cap MUST be present and intact. It holds on the lower o-ring. without the pintle cap, you will blow out your lower o-ring and have massive fuel leaks.
Old Mar 26, 2005 | 06:20 PM
sleeper's Avatar
summary
purpose of pintle caps on injectors.
  1. protect injector nozzle
  2. channel fuel away from nozzle at shut down
  3. hold on o-ring
Miket2006
Mar 1, 2021 03:55 AM
05RLS2
Apr 14, 2016 11:49 AM
captchaos
Mar 15, 2016 12:18 PM
msellas
Sep 23, 2015 09:16 PM
