Progress on the Kit (pics)
Old Jun 5, 2005 | 01:04 PM
Oblongshapes's Avatar
Heres where Im at, Hopefully tomorrow I will have the downpipe ran
Im going with a 3 inch cat and dynomax superturbo muffler... what dimensions fit back there? Any suggestions?
Old Jun 5, 2005 | 01:06 PM
|Bijan|'s Avatar
UCF Lexus
sweeeeeeeeeeeeeeeet
Old Jun 5, 2005 | 01:19 PM
I30tMikeD's Avatar
ahhh the memories. Looking good. Have you test fitted the reverse y-pipe yet? How close is the feed pipe to the tranny?
How is the turbo mounted in the engine bay?....kinda looks like your using the same battery tray bolt hole that I used.
keep us updated.
Old Jun 5, 2005 | 01:36 PM
Nealoc187's Avatar
SLOW
What's the A/R on that? Was it you who posted pics of the 60-1 a couple weeks back?
Brad92SE's Avatar
Looking good! Are you putting the pipes together yourself?
Old Jun 5, 2005 | 01:38 PM
Nealoc187's Avatar
SLOW
BTW that's a nice garage setup there. Is that a shop or someone's house?
Old Jun 5, 2005 | 02:35 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
i like them. where are you located at?
Old Jun 6, 2005 | 01:53 AM
Yea, Im making the whole thing myself, the actual y section is warpspeeds chopped at the collector, and Ive just been measuring and welding bends onto it from summit. The turbo is mounted just with some scrap metal I had laying around, but I bought angle iron and im going to use that to make a bracket that I can disconnect from if ever needed.
There is decent clearence fromt he tranny, probably 1/2-1 inches under it where the flex pipe is and 2 inched on the side.
The place is actually my school... Wyotech, Im going their for automotive technology and now im in my elective class of Chassis Fabrication and High Performance engine. My project to graduate is turbocharging the max. I also just got done making tube frame rails for a 1932 ford roadster.
its a .50 compressor and .63 exhaust
Old Jun 6, 2005 | 06:55 AM
slimer's Avatar
that'll give a quick spool then.
Old Jun 6, 2005 | 07:00 AM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
no the 60-1 is me im starting putting the thing together in about 2-3 weeks waiting on some pipes.
Old Jun 6, 2005 | 07:16 AM
JAY25's Avatar
Great job!! You dont need a flex section there is on your down pipe that you will need that flex section.
Old Jun 6, 2005 | 07:19 AM
JAY25's Avatar
that .63 AR compressor is going to choke up top. Too small!! .7? or .81 would have been better. You will spool up faster on low end.
Old Jun 6, 2005 | 08:02 AM
yeah unless your also running a diff ecu and a mevi, your gonna choke out pretty bad top end
Old Jun 6, 2005 | 11:04 AM
i know its a little small, but i picked it up cheap with plans to get a new one as soon as i get money.... it will work for now.
Old Jun 6, 2005 | 12:54 PM
choray911's Avatar
The Crazy Azz Cracka
Oh snaps!!!! Lookin good. That has to be a tough final, turboing your own car.
Old Jun 6, 2005 | 01:17 PM
subs1000w's Avatar
are you planing on using an intercooler
Old Jun 6, 2005 | 02:24 PM
Nealoc187's Avatar
SLOW
is that a t3/t4 or a t04. what wheel is in it also.
Old Jun 6, 2005 | 03:28 PM
subs1000w's Avatar
its definitly a T3 turbine housing
Old Jun 6, 2005 | 11:36 PM
I dunno, it says t3/t4 and t04e on the badge....
its a 57 trim
Old Jun 7, 2005 | 08:21 AM
Chief Brody's Avatar
Nice, it is my car turbocharged. I like it.
Old Jun 7, 2005 | 07:16 PM
Mximus's Avatar
lookin good, im hoping to start work on a custom kit by the end of the summer after i get all the bugs worked out and all my questions answered. just put the mevi in in preparation although i havent wired it yet. im waiting on ash to finish that new ecu setup for the 4th gen max, if its anything like the 300zx ones it should be a killer set up. ive got a couple of questions while you guys are on turbos. considering the mevi and hopefully a raised rev limit should i be looking at a turbo with both turbine and compressor sides larger than .63 so it doesnt die in the top end, or should just the compresser side be larger (ive never quite figured out what effects what yet although im still researching). Any opinions would help. Thanks.
Old Jun 7, 2005 | 09:00 PM
Nealoc187's Avatar
SLOW
Yeah that's a pretty small A/R especially on a T3, but as long as you are planning on upgrading it soon it will not be that bad to start out I guess. But yeah Jaime and others are right, you are going to choke up top really really bad with that. Will still be faster than without the turbo though
Old Jun 13, 2005 | 10:09 AM
Heres some more
Old Jun 19, 2005 | 05:42 PM
midnightmax01's Avatar
thats gonna be a pretty sick setup man. good luck, hope you wish me the same seeing as that i will be starting on mine as soon as im done with school for mercedes.
litch
123
Jan 4, 2024 07:01 PM
JonBlz
Oct 5, 2015 06:02 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
