MAP Sensor Code.
Old Jul 7, 2005 | 10:48 PM
jeremykedel's Avatar
MAP Sensor Code.
Boosting 8 psi, Can figure out the vaccum to the map sensor, Any one have any diagrams?
Old Jul 7, 2005 | 11:23 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
what is there to figure out?
look on the underside of the hood to see the vacuum diagram.
Old Jul 9, 2005 | 08:52 PM
But it is hooked up and keeps throwing the code i figure it is because of the boost.
Old Jul 12, 2005 | 07:12 AM
Shadow's Avatar
It is because of the boost. The MAP sensor is a diagnostic sensor, and it's not designed to see boost. I keep tripping mine, it's keeping me from passing emissions.
I've swapped to two different MAP sensors, and checked the vacuum routing, still the same problem. It's funny, I only threw that code twice in over a year with the supercharger, and now with the turbo, I can't go 50 miles without throwing it.
Old Jul 12, 2005 | 02:20 PM
Well i wonder if anyone knows how to make it not see boost, lol. I just dont liek the light on, in florida we dont have to worry about emmissions like everywhere else. Well i will try something and see if i can figure out how to fix this.
Old Jul 12, 2005 | 02:24 PM
95turbo gxe's Avatar
I think you may can use a check valve maybe. Or something like that
Old Jul 12, 2005 | 03:34 PM
Maxima lover
Here is a link, its from an integra, but it should work on a max.
http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
(about half way down after the parts and prices)
It's how you trick the MAP sensor using check valves.
Old Jul 12, 2005 | 08:03 PM
cool will try.....
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
zmcneely13
Sep 26, 2015 02:26 PM
