When will this turbo spool?!
Old Aug 16, 2005 | 01:14 PM
Starchild2K2SE's Avatar
Here is the turbo, it is a garrett t3/60-1 turbocharger. Here are the stats:
COMPRESSOR SPECS:T04S housing
flow: 61 lbs/min 781cfm
.70 A/R housing
60 TRIM wheel
TURBINE SPECS:T3
.63 A/R housing
HIGH FLOW 76 TRIM stg 3 wheel
oil lubricated centersection.
for use with external wastegate.
COMES STANDARD WITH 360 DEGREE THRUST BEARING!!!
supportable of 575whp!
With those stats, I assumed the turbo should start spooling at about 2500rpm on the vq35 and hit full boost at about 3500rpm. Does that sound right? Correct me if im wrong.I need to know ASAP before I make my decision wether to order this turbo or the garrett gt35R. Thanks.
Old Aug 16, 2005 | 06:02 PM
MaXtUneD's Avatar
I have the same exact turbo and I see full boost at 3000-3500 rpms all the way up to redline....Boost doesnt fall off...
Old Aug 16, 2005 | 06:33 PM
Nealoc187's Avatar
SLOW
You know what I think about it. Just responded to your PM. When it spools depends entirely on your piping setup though.
Old Aug 16, 2005 | 07:05 PM
Im going with a reverse y-pipe setup, like most of the other custom turbo kits for the maxima's, and also like pimpjuice had his 3.5L setup. But i think im leaning toward the garrett gt35r turbo again.......man this **** is really getting to me......too many options...LOL......
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
