complete turbo kit
Old Aug 29, 2005 | 04:36 PM
ShadowMav's Avatar
complete turbo kit
hey u trubo guys have u seen or bought from this company????
http://www.turbo-kits.com/maxima_turbo_kits.html
and if so did it just "bolt on" as the guy told me it would when i called him...he said supposedly it come with every thin including a manifold, crossover pipe to fun off both banks and a down pipe any info on that site will help
edit: and what the diff between the tsi and the pfi kit?????which would be a better choice and y???
Old Aug 29, 2005 | 06:15 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
that kit runs off 3 cylinders...I think harry of paradox has it on his car. I've seen it in person and the manifold was nice, but running off 3 cylinders =
the PFI kit is much better, go with that!!!
Old Aug 29, 2005 | 09:37 PM
choray911's Avatar
The Crazy Azz Cracka
The PFI kit is made very well, and almost bolts up perfectly. There is some trimming and cutting needed but the kit is a whole is supurb. However there are a few things you will need in addition to the kit. 1st thing you will need is some kind of fuel management, either a SAFC II or Greddy E-Manage. I started with a SAFC II and it worked good with the kit, however I had greater asperations and switched to E-Manage. The price difference is about $200, but E manage is a whole lot more advanced with greater adjustability in respects to fuel management, timing control and, injector changes. The second thing is a fuel pump with greater flow. I think every one on the forum uses either the walbro 255LPH, or the external pump that comes with the Stillen supercharger.
In respects to the TSI kit I couldn't tell you, I haven't seen one and I have no clue how well it runs off one bank.
Choray
Old Aug 30, 2005 | 03:56 AM
ShadowMav's Avatar
the guy that i talked to said the the tsi kit ran off of all 6 cyl. and that it came with a cross over pipe to connect all 6
Old Aug 30, 2005 | 06:09 AM
DA-MAX's Avatar
well it must have been updated since the first run because I've seen it in person and it was not that way at all. I would think the manifold would be similar to the VG30ET, but its was no where close. a front manifold with 3 runners is all I saw...
Old Aug 30, 2005 | 11:50 AM
ShadowMav's Avatar
really.....ill have to see....but if it does run offa both banks would it be a good set up????he also said the it came with all of the fmu stuff u need. any of u with either of those "kits" installed that are near southern nh i would like to see the setup in person....if u do have it and don't mind meetin me some time pm me
Old Aug 30, 2005 | 12:52 PM
DA-MAX's Avatar
technically the other kit would be "better" cause of the manifold setup, but then again, this "crossover" pipe has yet to be seen and could totally void the efficiency of a good manifold setup. also the T25 they give you isn't exactly phenomonal either. IMO PFI still wins, design, options and its PROVEN and TESTED!
Old Aug 30, 2005 | 04:02 PM
choray911's Avatar
If you were to run a t25 off both banks that thing would choke out the motor. Our 3 litres produce way to much exhaust to flow efficently through a t25. In order for the t25 to work it would have to run off one bank.
Old Aug 31, 2005 | 02:52 PM
ShadowMav's Avatar
the guy a turbo kits talked to his manufacturer and he said yes it deff ran off of both banks
Old Sep 1, 2005 | 09:43 AM
maxgtr2000's Avatar
KH3 by popular demand
That's weird, I would think it would be one bank, I wonder what the $300 difference in piping price I got quoted between PFI and TSI was for.
Old Sep 2, 2005 | 08:24 AM
DA-MAX's Avatar
if thats the case, this is might not be that bad an option...though more exact info or pics would be nice. there are plenty T25 custom flanged turbo upgrades used by the DSM guys that flow well up to 600hp. not too pricy either
Old Sep 26, 2005 | 07:31 AM
v6maximus's Avatar
I have a Nissan E-spec 180SX type S13, it comes with the CA18DET engine wich is a 1,8 litre DOHC 4 banger with a T25 turbo.
The turbo starts building boost @2k rpm and is on full boost @3k rpm (1 bar)
then when I hit ~6k rpm the boost starts to drop off.
So if the T25 chokes allready on a 1.8 litre four banger, think about how it would behave on a 3 litre V6! It can't even hold boost till the SX' 7500rpm redline, and that's a tiny 1.8 litre engine... This engine died recently and I'm saving up for a RB25DET swap for the SX, till that time I'm gonna drive a E-spec Maxima again (cefiro bodystyle)
Bottom line, the T25 is to small for the VQ30, it would even be to small for the VQ20... Could be a funny turbo for a pulsar 1.6 I guess..
And how the hell do you make 600hp out of a T25?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Luev
Sep 30, 2015 11:50 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Pied
Sep 26, 2015 03:29 PM
