Turbo too big?
Old Sep 6, 2005 | 09:33 PM
jcy98maxse's Avatar
Turbo is too much fun!
Turbo too big?
Is this turbo too big for our 3.0?
compressor: GT40
.70 a/r
61mm inducer
flow: 65 lbs/min 832cfm
turbine: T4
your choice of T4 turbine housing
available with 0 or P trim wheel
add $100 for Q-trim wheel
360* thrust bearing standard
*same compressor section as GT35R
I'm looking into this package deal:
http://store.yahoo.com/cheapturbo/40pa.html
which turbo would be better? T3/GT40 or T4/GT40?
Old Sep 6, 2005 | 09:35 PM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
its the same size as mine it would be fine, i though it was bigger when we talked.
Old Sep 6, 2005 | 09:39 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
T4 gt40. The t3 will have trouble flowing up top.
Old Sep 6, 2005 | 09:51 PM
Nealoc187's Avatar
SLOW
No it's not too big.
Old Sep 6, 2005 | 10:00 PM
jcy98maxse's Avatar
thanx guys
Old Sep 7, 2005 | 10:44 AM
Maxima4lyfe22's Avatar
I have an 2002 maxima GLE automatic. I bought a turbo and am having a manifold custom made for my car i bought the intercooler and blowoff valve i was told since i was not going ot be boosting more then 10 lbs i wouldn't need new injectors or fuel pump. What i'm concerned about is the transmission. If any of you know about what i'd ahve to do or if i would have to do anything to the tranny plz post a reply or email me joejoe2262@yahoo.com. I was told since i was not boosting that much i would not have to make any modifications to the tranny but i'm still not certain.
Old Sep 7, 2005 | 02:15 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
For $110-$130 more then their non-package price, you can get get a TRUE dual BB Garrett GT35R here:
http://my350z.com/forum/showthread.p...69#post1676169
It has a T3 flanged 0.63 A/R turbine, which would work for a mild-medium boosted stock rev-limit VQ30 and I'm sure even more.
IMHO, stay away from GT wheels in T-trim housings especially ones with mix-matched unknown "ABCDEFG" trim turbines. Garrett spends a lot of R&D to pick the proper combinations of wheels and housings, so unless you plan on trying several to match your setup, you probably won't find anything better. Let alone somebody out there just slapping things together. Just my .02.
Old Sep 7, 2005 | 03:02 PM
Nealoc187's Avatar
SLOW
I suggest you not take the advice of whoever told you these things anymore. To get anywhere even close to 10psi you are going to need fuel upgrades, and I have a feeling a stock auto trans is going to let go in pretty short order if you get close to 10psi as well. Also there's a ton more to a turbo kit than the turbo, piping, intercooler and bov just so you know.
Old Sep 7, 2005 | 06:49 PM
Starchild2K2SE's Avatar
Im getting the garret t3/60-1, will that have trouble flowing up top on my vq35? If so, should I just go with the t4/60-1?
Old Sep 7, 2005 | 07:01 PM
Nealoc187's Avatar
SLOW
Absolutely. T3 almost any AR is pretty darn small for a 3.0, too small in my opinion but some people would argue otherwise. For a better breathing and larger 3.5 it's too small without question.
I don't know what your power goals are but I'm not a fan of the 60-1 compressor. For most people that get them, there are better turbo choices out there.
Old Sep 7, 2005 | 07:06 PM
Im not a noob to turbo systems, but what would you recommend that I get.
Old Sep 7, 2005 | 07:58 PM
Nealoc187's Avatar
SLOW
Ummm... that's why I asked what your power goals are...
Old Sep 7, 2005 | 09:13 PM
jcy98maxse's Avatar
350whp-375whp daily, 450whp max
Old Sep 7, 2005 | 09:33 PM
I30tMikeD's Avatar
And you dont think you need larger injectors or even a different fuel pump?
Old Sep 7, 2005 | 09:36 PM
jcy98maxse's Avatar
wat makes u think that??? I pm u when I bought ur FMU saying i was upgrading those things... just cuz I'm still a noob in this doesn't mean I'm gonna do it recklessly. Those numbers I don't plan on acheiving right from the start, I just want to know what size turbo would be capable of reaching those numbers.
Old Sep 7, 2005 | 11:35 PM
Nealoc187's Avatar
SLOW
My question about power was directed at starchild not jcy98. he asked what turbo i thought would be best but that question is not possible to answer without knowing his hp goals.
Old Sep 8, 2005 | 07:22 AM
I30tMikeD's Avatar
Never mind, I got confused with you and that other guy jacking your thread.
Old Sep 8, 2005 | 09:33 AM
7psi on stock injectors with a super afc and a inline fuel pump..
Old Sep 8, 2005 | 10:06 AM
SPiG's Avatar
SomePsychoGuy
That isn't a power goal. 7psi on a T3 is vastly different from 7psi on a GT40R.
Old Sep 8, 2005 | 09:28 PM
mforrest100's Avatar
I know this man. I think his power goal is anywhere from 325 - 350, possibly 375. Is that doable with what he wants to run? Or should I say what turbo would you recommend to run at 7 psi, stock injectors, and in line pump to get close to these numbers.
Mike
Old Sep 9, 2005 | 12:27 AM
Nealoc187's Avatar
SLOW
With a VQ35 and 7psi on an appropriately sized turbo you could be lookin at around 350-380.
Old Sep 9, 2005 | 12:57 AM
Preach on brotha, i got the 60-1 t4 well see how it handles and runs, and if i dont like it ill switch to a gt series
Old Sep 9, 2005 | 12:58 AM
jcy98maxse's Avatar
Okay, With this turbo (T4/GT40); 38mm Wastegate; Forward-style feed pipe (2.5) and 3 in Downpipe with a 3in cutout. What type of numbers should I see @ 7psi? Assume that I have the neceessary fuel management: 550 injectors, SAFC/Emanage; Z32 MAF; FMU; 265lph Pump and AFPR.
My power goals is like I said 350ish whp daily and around 400whp on 3.0 5spd max.
I want to know if this turbo is good enough to get me there or should I be looking at something else.
I looked into the GT35R from the link Icy gave but thats from a private seller so I dunno if it would still be available. Also reading Turbo97se's thread on the GT35R, he actually have a special trim which isn't like the ones you find off the shelf plus I don't think I'll have that much $$ just to spend on the turbo.
So guys what do you think?
Old Sep 9, 2005 | 01:11 AM
t4 60-1 will get you over that 400whp barrier.
Old Sep 9, 2005 | 01:28 AM
jcy98maxse's Avatar
yes I know ur turbo can pull those numbers but I want a little bit quicker spooling turbo. remember I won't have a JWT like u so I have a stock rev limiter. If I remeber right, you say u see boost @ 4500rpm that leaves me with little room to work with.
Plus I could use a 35 shot to spool it even thought I'm set up for it. I kinda wanna stay off the bottle to get those numbers and spray to get higher. but I know you can't get the best of both worlds quick spool with high power without spending a lot $$$ but I just want a well balance turbo that I can play with. If there isn;t a good one,i'll consider other options. The luxury of not making a impulsive purchase and people with experience in this field.
Old Sep 9, 2005 | 07:05 AM
Thats why im getting a t3/60-1, I don't wanna see spool at 4500rpm. I mean my car gets up there so fast now, but at 4500rpm, boost-redline-shift, that is too much for me. I'd rather have trouble with torque steer than have my turbo spool up at 4500rpm. My friend has a 99 maxima, 60-1 turbo and he needs 1/4 of a block just to blow off. C'mon........
I know I have a bigger motor in the vq35, so I should be able to spool up quicker than a vq30 with a 60-1, but im just going to get a t3/60-1, if I don't like it I can always sell, there are alot of turbo feens around my way, so it wouldn't be a problem selling.
Old Sep 9, 2005 | 03:00 PM
Nealoc187's Avatar
SLOW
MardiGras has posted a ton of datalogs of his PFI kit with T4 60-1 over the past year or two so you guys could see exactly when he spools if you would check out his threads...
I also don't know how many times I've said this, it's probably going on 10 now, but your turbo piping has as much to do with how quickly your car sees boost as the specs of your turbo.
I don't know how much more advice I can give on the subject of ARs without repeating myself over and over again.
Old Sep 9, 2005 | 03:24 PM
jcy98maxse's Avatar
yes I understand that Neal. Hence I post with the style and size of piping I am trying to run. BTW its Mingo's piping setup if he comes thru... I appreciate your help very much and am not trying to annoy any of you turboed guys out there with these questions.
My question wasn't directed to how soon the turbo will spool rather than if this turbo(T4/GT40) is adequate to put down the numbers of my power goals. I can live with a later spool but prefer not to.
Old Sep 9, 2005 | 03:40 PM
Nealoc187's Avatar
SLOW
This last post was directed more at starchild and others who insist on using inappropriately sized turbos, your turbo won't be a problem. There are better (and more expensive) turbos, but it's not bad. A t3 60-1 is a turbo sold in a alot of the higher power honda B Series turbo kits (not that it's well suited to that either, but that's not the issue here).
Old Sep 16, 2005 | 02:23 PM
jcy98maxse's Avatar
Wat turbine spec should I choose with this turbo? .58 a/r, .70 a/r, .84 a/r. I'm thinking .70 would that be a good choice?
Old Sep 16, 2005 | 02:24 PM
slimer's Avatar
Since its a smaller turbo a .8x would give you a little more headroom.
Old Sep 16, 2005 | 10:14 PM
maximariceboi's Avatar
sorry kind of new to this...thinking about using a garrett gt35r...will i need to do any engine modifications? thanks
Old Sep 16, 2005 | 11:13 PM
jcy98maxse's Avatar
heres a link from PFI's old thread...
http://forums.maxima.org/showthread.php?t=361469
Old Sep 17, 2005 | 10:58 PM
jcy98maxse's Avatar
headroom meaning more power output or efficiency?
would the .8x ar affect 1/4 times. From wat i read in the FAQs the .8x is more of a highway setup while the .6x is for more track/street so I figure the .70 would be decent, somewhere in the middle. any other opinions?
Old Sep 18, 2005 | 01:35 AM
Nealoc187's Avatar
SLOW
You heard right. Given the same piping and every thing else, .8x will be a little more laggy. .70 will see boost a few hundred rpm quicker. you don't really need to go .8x unless you are looking for to make really big power like 400 or 450+
Old Sep 18, 2005 | 01:36 AM
Nealoc187's Avatar
SLOW
Also, if you don't like the turbine you end up with you can always change it later for like $150 and sell the one you take off there.
Slimer, the one jcy is looking at is a t4 not a t3 so .70 is pretty good, that's the size mike runs.
I've got a .84 personally but I'm making more power and running more boost than most folks, and also have higher flow piping than everyone else too.
Old Sep 18, 2005 | 08:58 AM
slimer's Avatar
There's so many guys that are contemplating turbo's right now, I get confused.
Old Sep 18, 2005 | 05:12 PM
jcy98maxse's Avatar
Neal- do you think it will give me problems in terms of it surging or not being efficent at higher boost? I don't think it would but I'm curious to know. would this have a similar compressor map as a GT35r even though this isn't BB?
Old Sep 18, 2005 | 05:26 PM
Nealoc187's Avatar
SLOW
No it wouldn't surge. Higher boost is subjective... is 12psi what you consider higher boost or is 18psi what you consider higher boost, etc. Either way I don't think you will have a problem.
As far as the map I don't know because in the first part of your post it says its a GT40 wheel and then the second part of your post says GT35R wheel. Anyhow there are a number of GT40 wheels and a number of GT35R wheels so the short answer is that without more info I don't have a clue. But all of the possible wheels work pretty well for the max, some a little better than others but you shouldn't be in too bad of shape unless you are looking for more power than most people are making.
Old Sep 18, 2005 | 08:32 PM
jcy98maxse's Avatar
Yea the specs on this turbo is quite confusing... my 1st post was straight cut& paste from the website, first they say its a GT40 compressor but at the end of the page they say its a GT35R compressor section. So I have no idea which is it, I'll email or call em sometime this week.
As for higher level of boost, at most I would want is about 14-16psi. That won't happen immediately because I'm still contemplating on the method of retarding timing. I would prolly stay around 9-12 psi as a daily driver (at the moment I'm leaning towards Mike's temp. setup of 550cc/SAFC/Z32 MAF/A32 ecu. I prefer to get an EU once the bugs are worked out), I bought his FMU just in case i go different. Anything above 12psi is for the track so I want to get slicks first before I go.
BTW Neal- wat are you using to retard timing? I know you are running a good amount of boost but I haven't been able to figure out what you are using for that department. Wasn't ur car Hal's car before when he dyno like 500ish with nitrous? if so, r u running nitrous too?
Ultimately, I would like to see over 400whp after all is said and done. I'm planning on getting the .70 a/r for now and I'll dyno it to see where i stand. If I'm close I might just leave the a/r alone and put a 30-50 shot on top since I'm hooked for it right now. If not I'll go on for the bigger a/r or a bigger turbo but this is all just speculation for right now.
