Turbo or not
Old Nov 1, 2005 | 08:54 PM
Gangsta_Bob119's Avatar
Turbo or not
I got a 95 maxima with 140,xxx miles on it... Should i build up the internals and run a turbo or just do an engine swap and build up that engine and turbo it... i was thinking about doing an RB26 swap and doing a turbo.
Old Nov 1, 2005 | 09:11 PM
wunfstmax's Avatar
Yes yes yes, your on the right track. If I were you it would be best to start with the basics, you know tb coolant bypass mod, turbonator, a lower resistance intake air temp senser mod. Theres a good 25-30 rotor hp there. On a serious note though, take a look around in the sticky's, decide if you can afford a project like you want. Ill tell you like anyone else on here its not cheap at all.
Nealoc187's Avatar
SLOW
After reading this I say "not" to the question of "turbo or not"
IBTL by the way, I forsee this one potentially getting ugly.
Old Nov 1, 2005 | 09:15 PM
DandyMax's Avatar
3.5 in the works
Brain cramp... what's IBTL stand for?
Old Nov 1, 2005 | 09:16 PM
jcy98maxse's Avatar
Turbo is too much fun!
looking at your age and experience with a max, probably not. And are you planning on doing a RB swap on a max? If so maybe you should convert it to a rwd first.
2 Da Max's Avatar
in before the lock
Old Nov 1, 2005 | 09:44 PM
96_vqmax's Avatar
It's stand for "IN BEFORE THE LOCK"
YES,NO,NO.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
