how do u hook up a water cooled turbo
Old Nov 19, 2005 | 11:49 PM
mad-max98's Avatar
i just put the turbo on the car ,, it's water cooled and i wasn't sure what is the best way to run the coolant lines if u guys can help thnx
Old Nov 20, 2005 | 12:44 AM
Donald199's Avatar
You don`t really need to hook up the water lines, just leave them
Old Nov 20, 2005 | 12:52 AM
jcy98maxse's Avatar
Turbo is too much fun!
Thats a , coolant lines should be ran if the turbo requires it. Especially on a BB setup, it will reduce the heat and save your turbo.
As for where, tap the coolant line between the TB and EGR.
Old Nov 20, 2005 | 06:10 AM
I30tMikeD's Avatar
What kind of turbo?
I will see if I can dig up some pics of mine to help you out.
Old Nov 20, 2005 | 04:35 PM
JAY25's Avatar
Run the water lines. The 3.5s have a fitting on the rear of the block run it to the turbo etc..
jaime
Old Nov 20, 2005 | 07:09 PM
mad-max98's Avatar
i have a vq30de and turbonetics bb t3 t04 super H compressor
Old Nov 21, 2005 | 09:46 AM
SPiG's Avatar
SomePsychoGuy
There are coolant lines that run to the Throttle body and EGR on the IM. Run it inline with that or bypass them completely after you disable EGR and getting a bigger TB like pathfinder or modded DBW. I wouldn't recommend not running water to a water cooled turbo; it will lower lifespan of the turbo and make it overheat.
Old Nov 21, 2005 | 10:10 AM
Stephen Max's Avatar
jaime
Good idea. People may not realize it, but the VQ30 has the same hole in the block, but it is plugged.
Old Nov 23, 2005 | 09:44 PM
maxima_kid's Avatar
Ive heard a few others with that set up usually over heats the engine. Like with the gt30, others just plug it up.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
BobTX10
Oct 7, 2015 08:43 AM
