FS: 2000-2003 PE380cc injectors $425
Old Dec 10, 2005 | 08:16 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Plug-N-Play/Drop-in for 2000-2003 Maximas. Slightly used a few thousand miles. Price is shipped in USA.
PERFECT for SCers, but even turbo cars can drop their fuel pressure significantly for more headroom over 270cc/290cc OEMs.
PM me if interested.
Old Dec 11, 2005 | 11:06 AM
MyownNismo's Avatar
Future Camaro SS owner
If I was to use these what pulley could you run with. I would like to find the best setup to run a 3.125 pulley.
Old Dec 11, 2005 | 12:31 PM
IceY2K1's Avatar
I'm not sure what whp a 3.125" puts down, but 300whp is conservatively safe with stock fuel pressure. However, if you use a FMU to moderately(read safely) increase fuel pressure, they will support more whp then the V2 can flow.
Old Jan 13, 2006 | 11:03 AM
IceY2K1's Avatar
$375......can take pics if interested.
Old Jan 17, 2006 | 07:55 PM
JAY25's Avatar
that will provide enough fuel for a 3.125 pulley 11.5PSI!!! My fuel set up was good 13PSI with the turbo and I have 370cc.
Old Jan 19, 2006 | 09:43 PM
michaelnyden's Avatar
isn't the translation or rule of thumb usually 1whp for every 1cc the injectors are rated at without upping the fuel pressure? so for example 370cc injectors support around 370whp without upping the fuel pressure?
oh and icey2k1 can you take pics of the injectors please? thnx in advance
so the 2.87 or even the 2.62 wouldn't be a problem for these injectors (say about 350) on stock fuel pressure with about a 12.5:1 AFR...?
Old Jan 20, 2006 | 05:52 AM
IceY2K1's Avatar
It is more like 1bhp per 1cc, so 380cc ~320whp.
Or you could do the math and it's
(380cc/10.5)*DC/BSFC*6cylinders*0.85 ~336whp assuming a 100% DC(max 80% recommended) and a SC typical BSFC=0.55.
Old Jan 22, 2006 | 03:30 PM
what about $350 shipped?
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
jsmith24
Feb 1, 2016 12:35 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
