making cai for s/c v2, but bypass valve?
Jan 11, 2006 | 07:05 AM
the question is what to do with the bypass valve how does this work? i know at idle it will stall and under normal accel it will probably bogg? how do i correct this i'm confused ? please help....
Jan 11, 2006 | 12:08 PM
Do make it idle properly, you need to vent the charged air back into the cai pipe. It needs to be after the maf and before the blower. Since the maf is supposed to be x inches before the blower, you have x inches of space to vent in. Just get a large barb and jb weld that sucker in. It would probably be the easiest solution. Just make sure there are no air leaks.
Steve
Jan 12, 2006 | 11:29 AM
:o)
I'm not sure that I understand the question. And I certainly don't understand Steve's answer - went right over my head.
But, my understanding of your question is: You want to know what to do with the Stillen-provided (stock) tube that runs from the stock Bosch BOV to the stock 3" 'pancake' K&N filter after you install your CAI. Correct? If I am understanding you right, then the answer is: nothing. You do not need to vent the BOV back to the air filter. You can easily vent it to the atmosphere.
Jan 12, 2006 | 11:53 AM
The need for a reciculating BOV is where the MAF is on the tubing. If it is after the BOV like on the 4th gen kit then you can vent straight to air and never worry about it. If it is before the BOV like on the 5th gen kit then you would need a recirculating BOV, move the MAF in relation to the BOV, or use the Emanage function to compensate for the metered air that just disappeared.
I know people have had plenty of problems with the 5th gen MAF and I don't know how it will hold to being boosted, but putting it on the charged side after the BOV and SC would be the easiest solution. If you keep the MAF on the non-charged side then you would just need to route the air from the BOV to the non charged side after the MAF.
Jan 12, 2006 | 12:27 PM
Since Ntech is a 5th gen and its a draw through setup. He will need to put it on the non-charged side unless he converts it to a z32 maf.
Josh-I forgot the number on inches that is suggested (I think its 18 inches) I just put x in there instead.
Jan 12, 2006 | 12:53 PM
O.k., I get it now. It makes sense to me now that you guys have explained the MAF before vs. after the BOV and the 4th gen vs. 5th gen. configuration. Thanks.
Jan 13, 2006 | 12:14 PM
how would the z32 maf help? don't i still need to recirc to
bov? and if i had a z32 maf then i cound put it inline with the bov but before the valve correct?
Jan 13, 2006 | 12:41 PM
I think he meant convert to the Z32 maf so you can place it on the charged side, and then run it like the 4th gen setup (Intake -> Blower -> BOV -> MAF -> TB).
Jan 13, 2006 | 02:12 PM
ok i was looking at it and the only way to add the maf is to change the piping on the boost side, i have the v2 kit and the bov is about 8 inches away from the tb so, i come to a new question intercooler??? good idea or bad idea?
Aug 15, 2011 | 05:50 PM
1996 nissan maxima what ti fix first
I have a 1996 Maxima Ive had for about a year took to the dealership and they found all kinds of suspension problems what should i fix first they said i have RACK BOOTS TORN,CONTROL ARM BUSHING TORN,AXLE E BOOT TORN,P/S PUMP LEAKING,REAR SUBFRAME BU SHINGS CRACKED.
Aug 15, 2011 | 09:31 PM
Quote: I have a 1996 Maxima Ive had for about a year took to the dealership and they found all kinds of suspension problems what should i fix first they said i have RACK BOOTS TORN,CONTROL ARM BUSHING TORN,AXLE E BOOT TORN,P/S PUMP LEAKING,REAR SUBFRAME BU SHINGS CRACKED.
on so many levels......
Here, let me re-direct you....Post your question here.
http://forums.maxima.org/4th-generat...e-posting.html
