post pic of your Js safegaurd
Old Feb 20, 2006 | 06:47 AM
95turbo gxe's Avatar
post pics pf where you have your js mounted and how much boost you are running and how much you are retarding
Old Feb 20, 2006 | 10:42 AM
Chunger's Avatar
My other car is a Hybrid
Old Feb 20, 2006 | 02:23 PM
LatinMax's Avatar
That were my emanage is installed.
I will post pics of my J&S soon. It is under the shifler under the center console.
Old Feb 23, 2006 | 06:49 PM
huyqvu's Avatar
damn thats crazy. is the ecu floating or bolted in?
Old Feb 23, 2006 | 08:54 PM
JdoubleOe703's Avatar
teddibear703
do any of you guys have the J & S wiring diagram?? also, does anyone have a tutorial on the install?
Old Feb 24, 2006 | 12:00 AM
jcy98maxse's Avatar
Turbo is too much fun!
http://www.jandssafeguard.com/MaximaInstall.html
Old Feb 24, 2006 | 10:23 AM
John at J&S's Avatar
The adapter cables were too hard to make, so I designed the waste spark adapter module:
http://www.jandssafeguard.com/6cylNissan/350z.html
Old Feb 24, 2006 | 03:16 PM
jcy98maxse's Avatar
I have yet to install the J&S and it came with the adapter cables, would it be easier to use the module? Is it only for '03 G35/350z ecu or compatible with a maxima too? If so how much for just the module?
Old Feb 24, 2006 | 04:27 PM
The module works on Maxima, 350z, G35, etc.
It's $35.
Note that the emanage cannot drive the 300 ohm coil simulator resistors presently installed in the J&S.
One solution is to make an amplified waste spark adapter module. Same price, but would need at least twenty paid orders.
Old Feb 24, 2006 | 07:03 PM
LatinMax's Avatar
It's $35.
OK, John I am confussed. Do I need this for my current setup.
Reminder: eManage and your J&S. You just re-built it for me after I blew 4 coil packs and you updated the firmware in my J&S.
If so, wat exactly does this do for me?
Old Feb 24, 2006 | 07:49 PM
jcy98maxse's Avatar
So with the module, I no longer need the adapters plus I dont have a emange so would you have this available already?
Old Feb 25, 2006 | 05:16 AM
Not only were the adapter cables hard to build, they also require that the installer have the correct tool to crimp the Weatherpack pins. The nice thing about them is you could easily go back to stock if you wanted to.
The adapter module has screw terminals. No crimper required. Easier to install, but not as nice to put back to stock. You would need to use butt slices, or use the adapter module as a terminal block.
LatinMax: I didn't rebuild your unit. I sent you a new one, with the latest output drive circuits. The original drivers worked fine on the early Maximas, but we lost a few coils when installed on 350z's.
I don't remember if I made your new unit emanage compatible (doubt it). Measure the resistance between one of the input channel pins and ground. Normally, the reading will be about 350 ohms. To work with emanage, the resistance should be about 10k ohms. Adding resistors between the emanage and the J&S won't work.
As I said above, the solution is to make new adapter modules with an internal amplifier. My design time is "free", but the pcb house has a $500 minimum.
James92SE
142
Jan 2, 2024 09:23 AM
Nv2dmaxmd
Sep 23, 2015 02:12 PM
Pixel
Sep 15, 2015 05:53 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
