S/C FMIC installed today
well i finally got my intercooler in the mail earlier today.. it is 30.5x3x12 over all the install really wasnt too hard to do, mainly just trying to get the front bumper off and removing the front bumper support bar. I havent had time to take it out for a test run but everything started right up and ran perfectly, and after a few hours of work, here is my result
yes, 30.5 is the overall width, its like 29 for the core and then with the ends its 30.5 once i have a chance later to go out and do a few runs ill see if there is any real noticeable drop in pressure
Originally Posted by Tatanko
So you were running piping down there prior to that? I take it you did that to make installing the intercooler easier when you got it?
Originally Posted by maxgtr2000
Maaaan looking at that gives me the chills..in a good way of course. I'm going to try to keep my fogs if it's possible. Looks awesome man.
Doesn't look like there's a whole lot of room for the fogs
i used to have fogs on my car a while back when i first bought it, but ya theres pretty much no room to have fog lights in there
Originally Posted by Brushedpewter
Why not cover the fog area? My altima has fog light covers because it didn't come with fog lights. If you were to do that nobody would thing you have a turbo.
Oh, and, he's supercharged...not turbo'd.
Originally Posted by JustMaxin96
where did you pick up the piping? By the way it looks great!
i bought a universal kit that came with my intercooler which i will be selling here sometime in the next week or so, but the rest of the piping is 3in and Stephen Max had put that together for me a couple months ago, i just had to change the middle pipes a little bit to fit the intercooler and get it centered where i wanted it
Originally Posted by MaxGordon7
so you have to leave off the front bummer support?
Looks good. Nice job. I don't like that you had to remove the front bumper though - for both your safety and the car/engine's safety. I don't suppose you have an air intake temp. gauge? I would love to know the air intake temp. with an air to air. With my water to air, my intake temps are reduced by 40-50^F at peak boost. And about 10-20 just driving around "unspirited". I have no frame of reference, so I don't even know if that is good or not. ? I'm very interested to know what temp. reductions are acquired with an air to air. Do you have a boost gauge? How much boost did you lose through the IC? With my aftercooler, I lost about 1.5 to 2 PSI (peak). I can't tell if you opened up that little area in the bumper cover above the large opening/below the grill (the place where the front license plate would mount) but you might want to, to increase the exposed surface area of the FMIC. Enjoy!
Originally Posted by Kenneth
Just in time for the summer weather... StephenMax did a nice job!
Stephen did the pipe work, intercooler install was done by me yesterday.. i finally went out and did a few runs on my way to and from class earlier and was seeing about 8 PSI when i usually see about 10PSI, so i would say overall that I lost about 1.5 to 2 PSI, but the car still feels like it pulls the same as it did before installing the intercooler, I am not sure about the exact drop in temperature, but im sure that if i can get a chance to do a little bit of tuning and such with Stephen on one of these weekends that i can get all of the info that you guys are after... and for the opening where the license plate bracket should be, the small plastic piece is still there, i havent had time to cut it out yet
Originally Posted by Stillen Maxima
Im in love......I love the way your car looks!!! Congrats
But this means no more Blow off valve right?
the car looks super clean. The intercooler I got is just a mishimoto (total measurement) 28x6x2.5. I did not want to cut the bumper support, but not running alot of boost either. I believe the bov is a maroon tial in the picture, bov I would say is still a must.
the BOV is still in there and still functions perfectly fine.. i have a video of my car that i made a week ago before the intercooler install just so everyone could hear the Tial 50mm BOV in action, ill try to get it on here later tonight
PM me, I can host it if you can't find someone/someplace to host it.
Werd, it's right where the driver's side bumper light would go. I think I see it in the pics you posted. What size pulley you running also? If you normally see 10psi, i'm guessing it is the 3.25" pulley. I have a 3" charge pipe and it gets insanely hot since it is so close to the radiator. Did he use any welds while doing this or is everything done via couplers? 8psi kinda discourages me. That isn't too far off from stock SC setup.
Originally Posted by TJ_Max
Werd, it's right where the driver's side bumper light would go. I think I see it in the pics you posted. What size pulley you running also? I have a 3" charge pipe and it gets insanely hot since it is so close to the radiator. Did he use any welds while doing this or is everything done via couplers?
let me know if the video works or not, my roommate hosted it on his computer and then deleted it so, if this doesnt work then ill just go downstairs and film another one, the video doesnt really do the bov justice since his camera couldnt pick up the full sound of the bov, but you can ask anyone thats heard it at wot, its pretty loud at times
http://lads.myspace.com/videos/vplay...ZPQ==&d=22
the bov is welded in, and everything else is done with couplers, and yes it is right behind the drivers side bumper light, if you look in the engine bay behind the headlight you can see the bov, im running a 3.125 pulley for right now, i might switch to the 3.0 just to compensate for the loss in pressure
Yeah, video worked. Sounds good. I'd make one of my ssqv but only sounds good on the move. At what psi does an intercooler setup keeps steady charge all the way through to the TB? I don't want to get hit with a bunch of stickies, just a simple number. You know off hand?
Like i said you car, looks sweet!! And since i dont race my car like that, i think this could be something i would do. Ssoooo Lets see the vid when u have a chance!!
Nice BOV
So how much was the cost of everything if you dont mind me asking?
i also still have my quicktime electronic cut-out waiting to be installed at the moment, i havent really had much time to try and mess around with that one yet, but i will be on the dyno later this year at Maxus, i just got too many other projects going on at the moment to get out to the dyno any earlier then that
Originally Posted by JSutter
are those measurements a typo? it looks way bigger than 9" tall.
We need before and after readings por favor.
