Woah what's this?
Old Apr 12, 2006 | 08:29 PM
DJ Technischer's Avatar
Woah what's this?
Nah just kidding . Any ways.
I have a 1988 nissan maxima , The one with the VG30E 300zx 9:1 compression engine.
And i have been talking to my friends , And my other friends at redline about doing a turbo project on my 88 , First of all people tell me not to boost a higher compression engine , Insted get the VG30ET engine and use that since it has lower compression 8.3:1 , But then other people say go with an aftermarket turbo , Put it on the 9:1 compression engine and the reason's why are:
faster spooling of turbo
more power throughout the entire rev range
much better low end power which makes for easier launches
better daily driveability
potentially better fuel economy as higher compression tends to get better gas mileage
And then people say i should only run 5-6 psi , And then other people say 8 , And then some one said 10......
See now i get mixed storys ... , People also tell me go with a T3/T04E .. Then others say...GT28R , I just dont know who to listen to!!! And then i get mixed info about electronics .....
Could some one please help me here...
Thank you!
Old Apr 12, 2006 | 08:54 PM
maxmaxima91's Avatar
First of all... Disregard anything people said about not boosting the stock 9:1 compression ration VG30... 9:1 is perfect.. At the moment, im running 13 psi into my Stock Original VG with 185000 miles on it... so thats not at all an issue. I even had my wastgate line come off and it surged to well into the 20-25 psi range.. .. but after that fact, a few runs later i ran a 110 mph trap speed, so the engine must be fine. As for turbo,.. well thats up to you. If you want Instant boost, go smaller, if you want TONS of top end... go larger. I perfer to be on the large side,.... but then again thats just me.
So as for the engine... as long as you have enought fuel going into the engine... 10.5-11.5:1 Air fuel ratio, and correct timing... you engine is basically garrentted not to die.. your factory engine is Perfect for boost.... i promise..
Jeremy...
Old Apr 12, 2006 | 09:35 PM
Humm , SO get like a mid sized ? I mean t3/t4 ? then some one also told me to go With a front mount and alchol injection.
Old Apr 12, 2006 | 10:06 PM
Front mount... yes... Alcohol... maybe when you get into the real high boost ranges.. under 15 and id say you fine without it.. maybe even higher... again... these engines are tough... but If there tuned incorrectly .. they will still pop.
Old Apr 12, 2006 | 10:16 PM
So do you think the t3/t4 would be a good first turbo ? And if i want some thing bigger move up a little?
And what Electronics do you recommend , And do you recommend i rebuild my engine ? , Or what ? and about mounting the turbo where do you think is the best? Its pretty small in there! , Shes tight!
Old Apr 13, 2006 | 06:18 AM
If your engine is running fine... boost it as is.. There is a guy in there that is running i think 12 psi through a 210000 mile engine.. without any problems. Electronics wise... the best way would be to tune your factory ecu.. this can basically be don the same way as im doing.... I belive. Bernard who is on this forum would have more information on weather it would work or not. ... i dont have time right now to get into all of the details of The tuning.
Old Apr 13, 2006 | 07:18 AM
And transmission wise ? I know i couldent swap the z31 trans in.
I have two option's.
Get some one to build me a racing auto trans , For 3000 dollars.
Swap a 5 speed in , and get a stage clutch from spec , With alum pressure plate , And alum flywheel .
Old Apr 13, 2006 | 08:51 AM
Blu's Avatar
Blu
the tits
sounds like you need to do A LOT more research...
Old Apr 13, 2006 | 09:01 AM
So what am i wrong about???
Old Apr 13, 2006 | 09:03 AM
Jeff92se's Avatar
I'm needing a caw
If you actually have to prove your "knowledge" by stating this:
Then you are already WAY in over your head. But if you still want to try this, I have a set of Z31 turbo exhaust manifolds with a T3 attached to it for sale.
Old Apr 13, 2006 | 09:17 AM
All i said was i cant swap the z31 tranmission in.
Old Apr 13, 2006 | 09:21 AM
because the VG30E in the z31 is like this
Trans here
_^_
.__
In 1988 max its like this
_____
| .....|> Trans here
I really doubt a z31 5speed would fit in there.
Old Apr 13, 2006 | 09:26 AM
subs1000w's Avatar
or pay a shop to do it, if you try with your corrent knoledge you will give the industructable VG a bad rap when yours blows up
start by reading ALL of this
http://forums.maxima.org/showthread.php?t=327382
and ALL of this
http://forums.maxima.org/showthread.php?t=392269
Old Apr 13, 2006 | 09:27 AM
Im just going to buy a new T3/T4 , So im sure it has no shaft play or any thing like that.
Old Apr 13, 2006 | 09:28 AM
Already have read all of that .
Old Apr 13, 2006 | 09:29 AM
And its not just me who will be doing it , A few people , at redline max.
Old Apr 13, 2006 | 09:30 AM
Jeff92se's Avatar
I'm needing a caw
Well duh! I know I can't swap in a T56 manual to my old maxima either. But anyone that knows anything realizes that it never has to be actually stated.
But thanks for the drawing
Old Apr 13, 2006 | 09:32 AM
When i said " All i said was i cant swap the z31 tranmission in." I was kinda thinking to my self , But typing it.
Old Apr 13, 2006 | 09:35 AM
Blu's Avatar
Blu
the tits
do you even know what the T3 and T4 labeling stands for? You cant just walking into a shop and say hey guys I want to buy a t3/t4 turbo you got any?
Old Apr 13, 2006 | 09:36 AM
Blu's Avatar
Blu
the tits
and I think you should go with a gt47/88 if you really want to be different.
Old Apr 13, 2006 | 09:40 AM
Why would i buy that ? , Its like buying some thing expensive and not even using half of it...
Old Apr 13, 2006 | 09:45 AM
Jeff92se's Avatar
I'm needing a caw
But you still need the manifolds and this can be converted to a hybrid easy when you get it rebuilt. Cheaper than a new unit
Old Apr 13, 2006 | 09:46 AM
How much are you selling it for?
Old Apr 13, 2006 | 09:56 AM
Jeff92se's Avatar
I'm needing a caw
Wait didn't you already buy a T3 kit?
Old Apr 13, 2006 | 10:20 AM
No , I was thinking about it...
Old Apr 13, 2006 | 10:46 AM
Jeff92se's Avatar
I'm needing a caw
I'll sell you a good T3 w/ all the Z31 manifolds for about $150+shipping. Let me know asap
Old Apr 13, 2006 | 10:57 AM
DanNY's Avatar
Ad·min·is·tra·tor
A/R?
compressor map?
Old Apr 13, 2006 | 11:06 AM
Blu's Avatar
Blu
the tits
Originally Posted by DanNY
A/R?
compressor map?
Now you've gone and done it, thats way over his head.
Old Apr 13, 2006 | 11:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
oops...ok nevermind.
Old Apr 13, 2006 | 12:54 PM
Humm , Witch turbos do you guys have?
Old Apr 13, 2006 | 01:24 PM
SPiG's Avatar
SomePsychoGuy
T3/t4, t04, or GT35R. RESEARCH. Read what other people have done. Spoon feeding FTL.
Old Apr 13, 2006 | 03:07 PM
Cutler's Avatar
I think you should get 2 T66 turbos, and you should reduce your exhaust to 1", remember turbos love alot of backpressure. That keeps the compressor running very efficiently. While you are at it why don't you just throw a SC on it too, that will help with the lowdown power, NOS can do the same too.....That's the set-up I am going with.......
Old Apr 13, 2006 | 04:58 PM
Im glad your going to fry your engine , Have fun with that UBeR CooOoO0L set Up DaWg!1!!1
Old Apr 13, 2006 | 04:59 PM
I was asking the people i was talking to on this thread.
Old Apr 13, 2006 | 07:08 PM
Broaner's Avatar
2060lbs and falling...
Douche...^
Weren't you just banned? I smell another one coming on.
Old Apr 13, 2006 | 07:48 PM
Originally Posted by Broaner
Douche...^
Im banned every week , Cutler just does it when ever he feels like it , Its just he has nothing else to do all day , and it gives him an adrenaline rush , then i get some one to unban me...
And why are you calling me a douche ? All i did was tell him that i was Wondering what turbos the people had i was talking in this thread it.
Old Apr 13, 2006 | 07:49 PM
Any ways , nice job on the 240 i saw the video pretty cool stuff.
Old Apr 14, 2006 | 04:13 AM
Blu's Avatar
Blu
the tits
search man, its that easy....
Old Apr 14, 2006 | 07:19 AM
Broaner's Avatar
Thanks for the compliment but I still think you're a douche. I can see why Cutler bans you. If I were a mod I would. Every question you're asking has been answered on this forum and in real books. Corky Bells...
Old Apr 14, 2006 | 08:48 AM
No thats not why he bans me ...... im in the dc forum 24/7 ....
