Have a question for MEVI guys.
Old Apr 19, 2006 | 08:37 AM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
I was looking over my engine bay yesterday for any type of leaks and I keep on hearing this hissing leak like sound comin from behind the MEVI, now I dont know if thats normal but I dont recall hearing that noise there before and im thinking this is the culprit to me running rich as hell and it being sh!tty. So to you guys with a MEVI, do you have a hassing sound coming from behind or from inside your MEVI system at all? I know if I put my ear upto the top part of where the butterlies are I can hear hising coming from somewhere and its quite loud. Ill try and get some video of the hissing.
Old Apr 19, 2006 | 08:41 AM
matty's Avatar
No hissing on mine. if it was a vaccum leak it would have a real hard time idling. Try and get a video of it
-matt
Old Apr 19, 2006 | 08:42 AM
My idle fluctuates a tad bit, but the hissing is so loud and im pretty sure I have not heard it before. Also I stated in another thread but ill re-ask the question here, is tehre anyway to test coilpacks?
Old Apr 19, 2006 | 08:55 AM
C MAX's Avatar
check your fuel injector, and just spray some throttlebody fluid(around where you hear the hiss) to see if the engines raises if so its a leak.
Old Apr 19, 2006 | 08:58 AM
ptatohed's Avatar
Licensed to Spell
You'll pull your hair out trying to test the packs. The best/easiest thing to do is swap with a set of known-good packs. Hopefully you have a local friend with a Maxi.
Old Apr 19, 2006 | 09:22 AM
hacim105's Avatar
To me from what you've described it sounds like you have a vacuum leak in one of the hoses that connect to the MEVI.
Old Apr 19, 2006 | 09:29 AM
Wish it was that easy. But i dont think thats what it is.
The hissing is throwing me off, it sounds as if its coming out from the back of the mevi where I cant see, or its coming from inside the mevi. Dont know . Also what do you mean if the enige raises, you mean the prm's?
Old Apr 19, 2006 | 09:39 AM
matty's Avatar
As you spray on the TB cleaner along the injectors and gaskets, if the engine recovers kinda, hickups, thats where your vacuum leak is.
-matt
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Marc2theMax
Sep 28, 2015 08:13 AM
Socalstillen
Sep 26, 2015 12:01 PM
