SC Guys, who has the Lexus metal pulley? (Belt Slip Fix)
Old Apr 25, 2006 | 01:21 PM
TJ_Max's Avatar
Paradox Systems Vendor
If you do have it, how do you get it off? What tool do you use on that 14mm nut? This pulley, for those that don't know, replaces the tensioner pulley in the SC set up. It's a wide flat metal pulley with no sidewalls. It allows the belt to slip left and right without snapping, jumping ribs, shredding, etc. That 14mm nut is kind of deep in there and the chasis is in the way. How did you guys get that pulley off/loose?
Old Apr 25, 2006 | 03:38 PM
ewuzh's Avatar
Don't have one, but try a swivel socket and a bunch of rachet extensions.
Old Apr 25, 2006 | 06:56 PM
Requin6's Avatar
would a wrench like this work....?
Old Apr 25, 2006 | 09:43 PM
maxlinegtr's Avatar
gearwrench.
Old Apr 26, 2006 | 07:33 AM
98MaXeDouT's Avatar
TJ, did u try a snake socket? I'm not sure if thats the name but its basically a socket wrench with a electricians snake as the extension..
Old Apr 26, 2006 | 07:47 AM
TJ_Max's Avatar
Originally Posted by Requin6
This actually might work. it would be perfect if the actual socket bent in a little deeper. I thought this would do the trick too. I'll buy one of these and see how it works.
Old Apr 26, 2006 | 07:50 AM
TJ_Max's Avatar
WHAT?!?!? Pics? Sounds perfect actually. I need an easy to use tool for this nut to keep in the car in case of emergencies. You all know how close that tensioner pulley nut is to the actual chasis. Imagine it being surrounded by a fat wide pulley. :sigh:.
Old Apr 27, 2006 | 11:30 AM
98MaXeDouT's Avatar
gimmie a min imma look for pics now.
Old Apr 27, 2006 | 11:35 AM
98MaXeDouT's Avatar
Something along the lines of that, but they come bigger, and with socket handles. I have one in the shop I work at in Maspeth but I wont be home till june :/
Old Apr 28, 2006 | 06:26 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I used a serpentine belt wrench on the last SC job....its basically a gear wrench with a socket and a long handle that can slide up in bewteen the chasis and pulley.
Old Apr 28, 2006 | 06:42 AM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
heat that wrench with a torch and bend it more thats how us navy guys do it
Old Apr 28, 2006 | 11:29 AM
TJ_Max's Avatar
You serious? LOL.
Old Apr 28, 2006 | 12:42 PM
Broaner's Avatar
2060lbs and falling...
It'd be alot easier if the car were RWD...
Old Apr 28, 2006 | 12:44 PM
TJ_Max's Avatar
LMAO, because the engine would be turned sideways and i'd have better access to the pulley?
Old Apr 28, 2006 | 03:02 PM
pawnstar12's Avatar
You serious? LOL.
yeah! we make **** work home skillet
Old Apr 29, 2006 | 08:02 PM
Broaner's Avatar
Precisely...
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
kenc15
Sep 25, 2015 06:38 AM
maxipower
Aug 21, 2015 11:10 AM
kirkhilles
Aug 8, 2015 10:53 AM
