FWD Drag Alignment
Old Apr 29, 2006 | 07:12 AM
MardiGrasMax's Avatar
FWD Drag Alignment
Getting my alignment done Monday. I have read some info on this. What I gather is zero camber for perfectly flat contact patch, zero caster and perfect thrust angle for no wheel friction. It has also been recomended that I set the car up exactly like I will run it, jack the back coil overs up and ask the slignment shop to lift the front end an couple of inches up with a jack when they align it to simulate the weight transfer. Do any of you guys have real world experiance on this or can you point me to a forum that I can find better info. Thanks.
Old Apr 29, 2006 | 10:21 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I would check the drag forums on Honda-Tech, Honda or not some of the fastest and most experienced FWD guys are over there...
2 good ones for example...
http://honda-tech.com/zerothread?id=1378753
http://honda-tech.com/zerothread?id=448278
Old Apr 30, 2006 | 10:20 AM
DandyMax's Avatar
3.5 in the works
Mardi let me know what you end up doing... I was thinking about this yesterday also and was thinking of jacking the coil overs way up in the back, then going with maybe -0.5 or -1 deg camber and a wee bit of toe-in but didn't think about lifting up the front. If you're going to do that then the question is how much does the front end come up on launch? I know there are expensive ways of measuring it but maybe something could be rigged up on the cheap...
thatcollegestudent
18
Oct 5, 2015 02:29 PM
06maxima55
Sep 28, 2015 04:29 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
