5th Gen s/c maf location?
Old Sep 11, 2006 | 07:19 AM
ToYLeT902's Avatar
JET Speed Lab
With the stillen kit, their are 2 pipes. The MAF goes onto the the pipe from the blower to the air filter.
Has anyone relocated the MAF onto the charge pipe like a 4th with the bov in the same or close to the same spot as the 4th gen? Turning the intake pipe into a cold air intake instead?
If this is done, is there any negative side of moving the MAF?
Old Sep 13, 2006 | 10:55 AM
Latinmax2
I tried and had all kinds of issues. Why? I have no idea, but the 5th gen does not like the MAF on the charge side. So I gave up and went back to the intake side.
I think there are others that have tried with similar problems.
Old Sep 13, 2006 | 06:28 PM
ToYLeT902's Avatar
JET Speed Lab
Thanks for the reply.
Old Sep 13, 2006 | 08:09 PM
michaelnyden's Avatar
there is a huge thread on here somewhere about it....it was either stephenmax who had all the issues or iansw...search for threads in the supercharged/turbocharged forum that they started...
I do remember that they had a lot to say about it...and figured something out in the end...
Old Jan 10, 2007 | 09:44 PM
iansw's Avatar
It was me that had problems for a year - until I decided to install 3" piping and on a whim tried it on that with the MAF turned 90 degrees from where it had been.
(if you use the stock piping for the 4th Gen it by default makes the MAF turned 90 degrees and does not work.)
If you put in 3" piping or cut and re-weld the flange for the stock 4th Gen piping to be 90 degrees different, then that works.
It's a sticky in the S/C Forum.
As for a 5th Gen - no idea.
Old Jan 11, 2007 | 06:33 PM
Ghase's Avatar
ToYLeT I did mines like a 4gen using custom 3" piping!!!!!! It's sideways in the sig, but it anymore...
Old Jan 12, 2007 | 12:25 PM
dfownz's Avatar
Is this problem only using the a33 maf? If I use the z32 will I be straight?
DF
Old Jan 16, 2007 | 07:21 AM
ToYLeT902's Avatar
JET Speed Lab
Gotta check it out one day if possible
Old Jan 16, 2007 | 04:15 PM
dfownz's Avatar
Can I get a link to that thread or can someone clarify the 5th gen issues? I don't want my maf on the intake side
DF
95Maxi
Sep 2, 2015 08:49 PM
95Maxi
35
Sep 2, 2015 10:37 AM
95Maxi
Aug 29, 2015 09:38 PM
95Maxi
Aug 25, 2015 08:01 PM
