theory of cooper plugs
i know alot of you boosted guys have been using copper plugs for heat exchange. is it because copper does not get as hot as other materials? is it bad to use a colder plug if its not made out of copper? also, anyone have a link on this theory?
Some people claim that under situations where detonation occurs its more likely that the copper will melt keeping it from detonating in that cylinder again... though I've not seen anyone test that for proof yet.
The other advantage to copper plugs is spark strength. Since copper is a better electrical conductor than platinum, a good copper plug will also give you a better, more reliable spark than a platinum plug (at least in the first half of its life).
Incidentally, iridium plugs with fine wire center electrodes (especially the ones from Denso) give you that spark strength without the short life. But, if you're FI, you should be removing your plugs frequently to check them anyway, so you're not actually saving yourself much labor by going with a longer-lived plug. You might as well just save some money with coppers and replace them more often.
good point...on a diffrent note i just now realized the title of my thread says "cooper plugs"...i'm special
I run IX becuase they dont blow out as easily as coppers, even at very low gaps coppers were blowing out even with the Boost A Spark. The IXs dont blow out because of the extra fine electrode. I've never had issues with melting plugs with any of the different types ive used. Keep the tune spot on and your golden. One set IX all the way for a whole season for me since its not really a street car anymore.
whats IX? iridium? can you gap iridiums? also, how do the heat range numbers work w/ iridium?
whats IX? iridium?
The only plug with a better spark is the Denso Iridium (its electrode tip is even finer), but it lives half as long and costs significantly more (~$13 per plug).
TKHanson
Nov 24, 2018 01:39 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
