Changing alternator on s/c max
my alternator is going and im going to change it for a high output one bc of my system and was trying to figure out how much more of a project this is going to be w/ my s/c on there? and i saw somewhere that you have to take out the fan shroud and the radiator, do you really have to do taht?!?!? im just hoping that i dont have to take off the s/c plate to do this!!!!
thanks for the help!
Ive taken off the alternator without messing with the S/C and plate. to make it easier on you...take off the radiator fan and/ or radiator...so much easier. Its just a long bolt with a square nut through, above the a/c compressor. pretty much 2 bolts that holds the compressor. long bolt that you have to go underneath the car to take off and that bolt that connects with the S/C...its long and tedious but doable. its just small area to work with good luck
RealityCheck
Aug 5, 2015 06:18 AM
