Emanage Question???
Old Jan 1, 2007 | 05:30 PM
crewchief264's Avatar
Emanage Question???
Alright I have an emanage blue 555 injectors etc,...... I have had the injector installed for a couple years no problem! Just installed the ignition harness soldered everything in according to the diagram, emanage harness white stripe wires to ecu, and then the emanage harness black stripe wires out to coil packs and I installed the resistors with the band facing the coil packs side of the harness.
I am getting spark at the plugs? ie the coilpacks are firing.
Heres my problem, when I open up the software I get online no problem but I can't access the ignition map, the icon never lights up its like the software doesn't recognize it. I am running the newest 1.49 emanage update?
What are all the jumper settings? I just want to make sure I have them right.
Do I have the harness installed correct?
Are the resistors installed correctly?
I was getting a ignition system fault also I tried starting the car but as ussual it flooded? No start?
Any ideas and or 555 injector maps people could send so I can doa lil comparison would be great.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
