Need Help With Turbo
I Have A Turbo But I Wanted To Mount It On The Manifold I Was Wondering If Theres Anyone Or Anywhere I Can Get A Manifold For A 98 Maxima Thanks For All The Help
Originally Posted by 98whitemax
i have two turbos and i am planning on trying a tt setup for those smart a**
I would watch what you say... people who have posted are some of the most knowledgable boosted maxima people here, them
you was in response to the very vague and indescriptive thread you started... I would get some information on your own, read some turbo books, and learn as much as you can before thinking something is easy and cheap and later you find its not. Help yourself first bra.
I see you only posted "turbo" not turbo's... Also jcy was right, there are two manifolds as we are dealing with a V6, so you would need "manifolds" what you are probably going to need is some sort of a feed pipe, maybe post what you have in terms of parts and we can help you with what you are missing and help you out that way, that is, if you don't get to hot headed first.
It does that when you type a post in all caps.
Typing a post in all caps would result the following:
I HAVE A TURBO BUT I WANTED TO MOUNT IT ON THE MANIFOLD I WAS WONDERING IF THERES ANYONE OR ANYWHERE I CAN GET A MANIFOLD FOR A 98 MAXIMA THANKS FOR ALL THE HELP.
Originally Posted by jcy98maxse
But he didnt type every letter in caps. Either he has a tendency of push shift as he types the first word or Caps lock is on and he is holding shift after the first letter of each word.
I just tested it in the test forum and it did exactly what his post shows. First letter is capitalized, the rest are lowercase. Maybe it only does it for the first post of a thread... go try it yourself.
but one can easily question such a thing as capitalizing each word when asking such as dumb question...
im not trying to disrespect anyone but everytime i post somebody has to say something like walmart but anyways i know its expensive and it not easy thats why i was asking if theres any manifolds for a 98 max
if its bothering you sorry for the capitalizing of the first letter but i didnt do it on pupose the caps lock was on and it does that when you are the first to post
Originally Posted by JeEvE
but anyway, dont bother trying to mount a turbo on the manifold, you will need a custom manifold and there is not much room for the turbo...
i tested two small turbos they fit just fine the thing that will be hard is getting all the pipes to the turbos the throtle body and the intercooler and all the heat will be crazy too but if it was easy it wouldnt be fun
well maybe you did test fit them using what bolts and what flanges and maybe it apperared to fit fine but like you said the pipes and the throttle and the cable and it would be crazy heat but it would be crazy fun but so what about some punctuation next time
litch
123
Jan 4, 2024 07:01 PM
Keyno McMike
Sep 21, 2015 07:18 AM
2 more months and I'll have it!
