belt size for 2.62 pulley on v2?
Mar 1, 2007 | 12:03 AM
what size belt should i use? i can find it in any writeups or stickies as for what belt size to use for the 2.62 pulley on a v2 kit?
Mar 3, 2007 | 03:12 AM
no one knows? =(
Mar 3, 2007 | 06:29 AM
i used a 4060695
Mar 3, 2007 | 10:52 AM
for v2 kit?
Mar 3, 2007 | 08:16 PM
yes that is what you asked for. I wouldn't just throw random number out there.
Mar 4, 2007 | 03:51 AM
ahh thx. i have one of those belts lying around. tried it with the 2.87 but it didnt fit very well.. =P
Mar 4, 2007 | 08:01 PM
damn! how did u get the 4060695 on? I tried on the one i had but it doesnt fit..it would need to be extremely stretched. I put on the 4060705 I had on and it just BARELY got tight enough but now the belt is rubbing itself between the 2 idler pulleys... btw my setup is v2 plate, asp idler pulley...please help asap i need to fix it by tomorrow.. =(
Mar 5, 2007 | 05:22 AM
i just had the tensionor as loose as possible. I put the belt around all the pullies and the a/c one was last. I had to muscle it on there but once its on its has some slack. I never had a problem with the 2 pullies rubbing each other, it means your belt is too long 705 is a whole inch longer than the 695. IIRC you had to use a weird belt size even before the 2.62 pulley. I know for a fact that the 695 belt worked and never rubbed anywhere.
