SC HeLp!!!!!!
Old Mar 24, 2007 | 05:38 AM
EpzMaxima96's Avatar
SC HeLp!!!!!!
Hey guys umm quick question. For my supercharger set-up I wanna do 3" Piping so do I need to like get a bigger MAF and an adapter to connect it to the Throttle Body? Also Im going to be running stock injectors for now and I wanna run the 3.25 Pulley what do you guys recommend for like FMU and like Fuel Pump? And if theres anything else let me know Im going to need as much help as possible! Thanks
Old Mar 24, 2007 | 11:12 AM
dfownz's Avatar
S-t-i-c-k-i-e-s.
Old Mar 27, 2007 | 09:38 AM
TJ_Max's Avatar
Paradox Systems Vendor
I'm going to have to agree with above. It isn't fair that we had to read the stickies when we were learning and you're just asking a lot of questions that are answered int he stickies already. Just trust us. You won't regret reading the stickies man. Good luck.
Old Apr 3, 2007 | 06:37 PM
JAY25's Avatar
8:1 FMU disk with stock injectors and that size pulley. Z32MAF w/370s if your going to get a Variable intake. You will run a bit lean up top. The stock MAF is a 3 inch MAF.
Old Apr 3, 2007 | 07:30 PM
i30ds's Avatar
Armed and Dangerous
Get two of these:
http://intakehoses.com/Merchant2/mer...egory_Code=RIS
One will go on the blower outlet and the other will go on the tb. This will allow you to run the 3'' piping trouble free.
Like Jay said, use a vortech fmu w/ 8:1 disk. Also drop in a walbro fuel pump. You will need a METAL MAF adapter from cattman. Its 3'' already, so there will be no problem mounting it to the rest of the piping.
