Help me identify what im missing from my V2
PLEASE VIEW UPDATE POST
V2 on V1
1) thermostat is mounted inside housing but missing the gasket.
2) Pancake filter & silicone tubing (optional CAI)
3) 3" MAF adapter
4) Oil feed line with T fitting
4) last bend to attach tube to blower head
5) fuel pump
6) NEW oil, boost and etc gaugaes ?
6) long tube and relocation bracket for windshield fluid
7) various bolts & nuts??
anything else?
thx guys, im still learning about s/c kits
V2 on V1
3) 3" MAF adapter
5) fuel pump
anything else?
Thats one of my kits
V1 FTW
1) MAF Adaptor (Get a Metal one, NOT plastic)
2) I dont see the T fitting on the Oil Feed line
3) No Drain Line
Oh yea btw, if you decide to install the headers, DONT Use those cheap exhaust manifold gaskets. They WILL leak on you. Get Nissan ones
V1 FTW 1) MAF Adaptor (Get a Metal one, NOT plastic)
3) No Drain Line
V1 FTW
3) No Drain Line
3) No Drain Line
anything else for this puppy to work?
Originally Posted by absoundlab
why do you have two fmu's?
That drain line in the picture isnt the right I.D. You need to use the proper size or your blower will build up too much pressure and will start leaking out the inlet
-matt
-matt
3) 3" MAF adapter
5) fuel pump
7) long tube and relocation bracket for windshield fluid
8) various bolts & nuts??
anything else?
3) 3" MAF adapter
5) fuel pump
anything else?
2. Also, the steel insert for Pancake filter if you decide to go that route.
3. Like Matty said, get a metal 3" MAF adapter from Cattman or ebay.
4. ??? You have what you need
5. yup
6. I recommend boost and fuel pressure. If you have the money, a true A/F wideband guage
7. I think you mean coolant overflow. You can fab a bracket, or just wedge it between stuff. Less weight/clutter
For the windshield reservoir, you simply twist the neck so everything fits.8. hard to tell. Just look at the parts list in the Stickies and compare. It's all there.
9. steel fitting 90 degree -4AN to 1/8npt (might be in SC already, you'll have to check and/or take more pics)
10. oil feed line should be -4AN ss
11. some way to secure ss line (at or around oil pan) See parts list if you want to know specifics
12. proper 5/16" barbed fittings on FMU? (can't tell)
13. Is that a 5/16" barbed fuel hose joiner in the pic? If not, you'll need one.
14. 3/8" ID power steering hose
15. Cam Sensor retainer
16. Permatex Ultra Gray sealant
17. What are you going to do about relocating (shifting) the fuse box near the power steering reservoir? You can easily fab something. See parts list in stickies and pics in the SCIFD on VQpower.com
That's it off the top of my head. Hope that helps some.
Originally Posted by Stillen Maxima
Welcome welcome welcome! Blower looks beautifull!! Mind me asking how much it cost you?
as for the price, i bought it used: http://forums.maxima.org/showthread.php?t=521098
thanks man, cant wait till i slap it on and do the 5spd swap. that wont happen till mid fall tho
Wow! you will love it. Specially when that 5speed swap gets done Vrrrooooom Phhsssssss!!
V2 on V1
3) 3" MAF adapter
5) fuel pump
anything else?
3) 3" MAF adapter
5) fuel pump
anything else?
BTW what headers are those?
-matt
-matt
As a rule of thumb, the outlet ID needs to be at least 4 to 5 times the size of the inlet ID. So you'll need at least a 1/2'' or 5/8'' ID hose. Get the front valve cover hose NEW from Nissan, and trim it to fit.
Also make sure there is ABSOLUTELY no kinks in it what so ever or else the oil WILL leak out the blower outlet and a rebuild will be needed... very important!
Originally Posted by glenmoormax
ill trade you intercooler pipeing for the headers.
and i would love to have a full cattman exhaust with headers, y pipe and catback but money is way too short. dont think that will happen
other than that, the T fitting just arrived from stillen. $32 for this sucka and the hunt continues
You can get away WITHOUT using the 120 degree fitting. Just loop it a bit more than normal towards the back of the car so the SS doesnt kink up and you dont put pressure on the T fitting.
-matt
-matt
V1 FTW
3) No Drain Line
3) No Drain Line
Originally Posted by mforrest100
This was my kit. Wonder why the guy didn't want to keep it. I don't know what you paid for the kit, but that blower and V1 plate is practically brand new. Enjoy it!!!
he had problems running the kit. did you buy the blower as well? it looks mint. i was wondering how many miles is on it the other day !
UPDATE
well 2 months later and ~$600 more, i believe the kit should be ready for bolt on but i am not certain. let me know if there is anything that i am missing and unaware of that i should purchase...
all help is much appreciated !
Mobil 1 10w30 Full Synthec
OEM Oil Filter
OEM Drain Plug
OEM Drain Plug Washer
BRAND NEW Walbro 255 LPH Fuel Pump & Installation Kit
NEW OEM Gas Tank O Ring
NEW -4an SS feed line with proper fiittings on both end
NEW Stillen T Fitting for the block
the 45 degree fitting from SS line to blower is on fedex truck and will be here tomorrow
OEM Oil Drain Hose (stock crankcase hose)
Practically new V1 Plate
Practically new V2 SQ Blower
Vortech 10 PSI pulley with proper belt
COMPLETE plate to blower and plate to motor bolt kit
NEW Idler pulley with spacer & 2 extra idler pulleys
NEW K&N 4 inch tall filter with 3.5" Flange. eliminating the use of reducer and metal flange.
not sure if fuse box relocation was due to blower clearance or filter clearance. if filter, then relocation will not be necessary with this filter
OEM Oil Filter
OEM Drain Plug
Oil Drain Back Plate
Thermostat Housing
Thermostat
OEM Thermostat Gasket
Crankcase filter
unknown gauge
Permatex Ultra Grey
Proper Screws and various other screws for Thermostat housing
MAF cleaner Spray
TB Cleaner Spray
3" Charge Pipe
Greddy type RS BOV with hose
Z32 MAF (or stock maf)
3" Metal MAF Adapter
3.00 to 2.75 Reducer Adapters for TB & Blower Discharge
Complete T bolt hose clamps
Proper IAT Sensor Plug
Vacuum hose tube will be welded on tomorrow at the shop
NEW Vortech 8:1 FMU
Proper Vortech Fuel hoses (6 foot 1/4" fuel hose, 6 foot 1/4" fuel hose, 6 foot 3/16" fuel hose)
12' 3/8" High Pressure Power Steering hose
6' 5/16" Fuel line for Coolant Bottle Relocation
$35 ebay intake comes with metal 3" MAF and the vacuum tubes will be cut off and welded to S/C Pipe tomorrow
For starters, your K&N filter looks kinda small. Have you checked the specs to make sure it flows enough??
i believe i30ds has/had it on his car with no problems.
http://www.knfilters.com/search/prod...x?Prod=RU-2990
[IMG]
i originally purchased the pancake but sold it because I30ds told me about the above filter and mentioned that airflow will not be restricted because the filter area is bigger. i trusted him and bought it instead of spending $20 on couplers. i plan to do 3.5" CAI in the future
Tell them you'll be running 10 psi and have 3.0 displacement. They crunch a few numbers and determine if it's good enough based on your engine and psi IIRC.
UPDATE
I know it looks small, but I got both the pancake filter and that other filter. I measured the pleated element surface area of both and they are equal. So, just like the pancake filter, it is still not ideal, but gets the job done until a cold air intake can be installed.
