grey smoke while trying 555cc
Old Jun 20, 2007 | 07:22 PM
95turbo gxe's Avatar
Ok I finally got the car to quit slinging raw gas out of down pipe and got my wide band working. My air fuel at the moment is 10.1 to 9.9. Im going to try and lean it out in a minute. BUt it keeps pouring grey smoke out of the down pipe. what could this be. I have not drove the car since trying to put these injectors in so I dont think is a headgasket!
Update Z32 maf
Hey im giving up on getting this car to run without it. I got the 555cc in and im still trying to use the stock maf. Remember I have no o2 due to that crazy rich problem with car a while back. I took the o2 off and let the eu bring it back to 14.7 at idel. with stock dek injectors.
Ok now I put the 555 in and I took 3.2 milly seconds out and it was stilll slinging raw gas out of down pipe and would make a gas puddling under the car. Ok took out 4 milly and it sound a little differant. Then I took out 5 and the motor speeded up and it sound a little cleaner but it lettting grey smoke out the down pipe. Ok well I kep going up taking more and more out hoping for it to get better and I went all the way to taking 12milly seconds out and it just makes it real choppy and still pouring gas smelling grey smoke out. with a air full floaty fastly from 9.8 to 10.5 afr.
SO im going to pull my maf off my z and see what happens. WIll I need to change this in the EU to the z32 maf setting! ANy other ideas on what may help?
Old Jun 20, 2007 | 07:35 PM
96sleepergle's Avatar
any codes my brothers i30 turbo had that problem turned out to be o2 sensor he was using 550cc nimso injectors do data log with scantool check fuel trims for left and right bank see which bank is dumping fuel , but check every thing with include engine its self my brothers i30 had a hole in the block when tilley pulled the motor down rod was snapped in half
Old Jun 20, 2007 | 07:58 PM
nah no codes Im not using the stock o2 sensors
Old Jun 20, 2007 | 08:08 PM
streetzlegend's Avatar
maybe its just fuel burning, did u do anything oil related? when i installed my turbo, i had routed my houses for the pcv system wrong. and i got crazy smoke.
Old Jun 20, 2007 | 08:10 PM
nah I no what your talking about. I havent changed the pvc line
Old Jun 20, 2007 | 08:15 PM
then thats weird man. it has to be extra fuel being burnt dude. nothing else. CANT be head gasket i dont think. **** i have a blown head gasket and i dont even let out smoke.
Old Jun 21, 2007 | 12:03 PM
SPiG's Avatar
SomePsychoGuy
You don't have any stock O2 sensors at all?
At idle the ECU should compensate for the huge injectors at least somewhat.
In EMU did you set an injector compensation or anything? Did you tell it you have 555cc injectors in there now?
Old Jun 21, 2007 | 01:05 PM
No I forgot about scalling them. Maybe thats it but do you know what the grey smoke could be?
Old Jun 21, 2007 | 10:51 PM
hmmm grey smoke, some what blueish?!!? Maybe its the turbo? when do you get the smoke? like all the time or when you start it?
I was getting a bit of smoke when i turned on the car, and it was grey. Ended up being an oil problem, the return line would allow for oil to flow back into the turbo when the car was off, so overnight or after a long time of being off the oil would go through the seals so wen u turned it on, smoke. i fixed it by running my scavange pump a couple of minutes after i turn off the car. how is the oil line set up on your turbo?
Old Jun 21, 2007 | 11:09 PM
SPiG's Avatar
SomePsychoGuy
scale the injectors, do a compression test, and check the oil and water (if there) lines on the turbo. That should cover most of the bases. If you still have the smoke after the engine is not dog rich then you have problems.
What else did you change besides the injectors at the same time when the smoke started?
From my understanding with larger injector differences you don't want to scale through the maps, but by playing with the actual scaling feature. Dandy or someone can correct me. Sorry if I am not using the official GReddy names for everything, but I don't have EMU yet, and I don't play with the program too much.
Old Jun 22, 2007 | 04:44 AM
The only other thing I did at the same time is the 6speed swap. I had to change the cps ring but I think thats fine!
Old Jun 26, 2007 | 08:59 AM
ok I went in and scaled the injectors today with not much luck. The smoke went away some and at times I got the air fuel to 13.0 but with some smoke still and gas fums in the air still but in my data log it does not show to be making any corrections! It shows the input and output duration to be the same. And the car is no where close to ideling. But in realtime when I make a correction it will rev up after correction though as if it is correcting but it shows to be the same on the data log. If anyone want to look at data log let me know
Old Jun 27, 2007 | 01:16 PM
im wondering if I put the Z32 MAF in will it help with cold start up. beacause I can get the car to idel after the temp hands goes to half way! ok well today I cranked it and it cranked right up and ideled, but its 90 degrees out and the car was cold!
Old Jun 27, 2007 | 02:42 PM
let me ask you. What exactly does the idle do when cold start? I always have to let the needle go above C to be able to drive the car because it does not allow me to rev, it just dies if i try to give it gas. its been like that since for ever. i just ignore it and it forces me to let the car and turbo warm up =). My problem started ever since i did the 00vi
Old Jun 27, 2007 | 04:09 PM
yeah thats one of the joys of the good ole oovi swap. I had that too I would have to hold the gas for about 10 seconds to get it idel when I had the oovi injectors.
knight_yyz
Nov 1, 2015 01:34 PM
Redfox
Sep 28, 2015 10:41 AM
ballerchris510
Sep 10, 2015 09:35 PM
