Stock Injectors w/ 3.12 in pulley and a V1?
Old Jul 27, 2007 | 02:44 PM
tsaulz's Avatar
I would like to use a 3.12 inch pulley when I install my supercharger this weekend, but I have not upgraded my injectors. Can anyone with stock injectors please chime in here? Are you guys bumping up the fuel pressure with a FPR or are you just relying on the FMU? What disc size are your running?
I was hoping that the 8:1 disc would give me enough fuel at ~10 PSI, but now I'm having second thoughts. I'll be running a stock ECU by the way.
Thanks in advance for your help.
Old Jul 27, 2007 | 03:11 PM
BlackCat's Avatar
RIP '98 Maxima SE
Although I 've left the injectors stock when I went to the 3.125" I've upgraded to a Walbro 255 fuel pump at the same time. Several weeks ago I revamped the fuel system and was running around with just an Aeromotive fpr @ 34psi and the BEGI/Cartech fmu offline, so that meant I couldn't boost. I could boost once I had the fuel adjusted while on a dyno, putting the fmu online. The 3.125" is supposed to give you 11psi so more fuel is needed.
At the moment I'm gathering up some 370cc injectors.
Old Jul 27, 2007 | 05:51 PM
tsaulz's Avatar
Thanks for the reply. I'll be running the Vortech Aux pump--would I need an adjustable FPR or could I get away with just the FMU?
Wizard, what fuel setup are you running?
Old Jul 28, 2007 | 12:22 AM
SPiG's Avatar
SomePsychoGuy
Well with the 3.125 on a V1 it should be about 10-11psi boost pressure. With an 8:1 FMU you would get 80-88psi fuel pressure. I have seen this done, but it is a bit on the risky side. Since it would only be at the very top of the rpm band and for a very short amount of time, it probably won't be a huge issue in the short term, but for really reliable boost you really need larger injectors and a quality tuning piggy back for large amounts of boost.
Old Jul 28, 2007 | 06:29 PM
BlackCat's Avatar
RIP '98 Maxima SE
I've noticed that with the pancake filter on and the 3.125" I wasn't able to reach 10psi until I put on the monster filter (see my other thread about moving the windshield reservoir). I was only seeing 6psi.
Old Jul 28, 2007 | 08:19 PM
tsaulz's Avatar
So I could install the 3.12 w/o upgrading my fuel, but just keep the pancake filter on to stay at 6 PSI until I upgrade my injectors, right?
Old Jul 29, 2007 | 08:16 AM
BlackCat's Avatar
RIP '98 Maxima SE
I would prefer that you hold off on installing the 3.125 until you have gathered all of the other ingredients: fpr, fmu, Walbro 255 and fuel rail adapter. Thats what I did.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
