going from s/c to turbo whats the best turbo around ?
Old Sep 8, 2007 | 05:58 PM
520whpNashville's Avatar
i have a vortech s trim v1 with mattys kit im wanting to swap to a turbo whats the largest and most reliable turbo i should go with also i will be posting the s/c & matty plate kit up for sale the kit is new never mounted with all parts in kit (non nickel plated) and the vortech s trim has been rebuilt by vortech never mounted since rebuild . please give any reliable BIG turbo options thanks
Old Sep 8, 2007 | 06:30 PM
absoundlab
let me know when you post the s/c forsale
Old Sep 8, 2007 | 06:47 PM
Nealoc187's Avatar
SLOW
It's been a long time since I've seen a post that was more vague than this. Bigger does not equal better in all cases. Set some goals for yourself and then get back to us after you've done at least a little bit of research.
Old Sep 8, 2007 | 07:20 PM
VIP Maxima
bigger = upper rpm kick in
Old Sep 9, 2007 | 03:19 PM
im looking for a maximum horsepower gain and a solid reliability range. the car is built to hold the power im just after some good turbo options hopefully 200+ horse just from turbo or more what are my options thanks for any positive useful feedback. (im thinking 2000.00 for the s trim vortech+ matty kit unused)
Old Sep 9, 2007 | 03:30 PM
VIP Maxima
do you honestly know anything about FI????
Old Sep 9, 2007 | 04:00 PM
ObsidianIce69's Avatar
t88? Gt60? Those are nice large ones...way overkill however. I by no means am an expert but..but you my friend definitely need to do some more learning before you just jump into this.
Old Sep 9, 2007 | 05:38 PM
maxima_kenny96's Avatar
200+hp on a maxima......getting hat would be like adding exhaust and intake to a 3.5
Old Sep 9, 2007 | 05:39 PM
NmexMAX's Avatar
dot dot dot ...
Pretty sure he meant 200+ from the turbo alone. So *insert stock whp #'s here* + 200.
Old Sep 9, 2007 | 05:48 PM
jesus f*ckin christ why is every post badgered by "guru" asses that have no positive input only ridicule for the people asking an honest tuning question YES i know of forced induction and YES im obviously talking 200+ from turbo add on and YES my max is built to handle it. so THANKS again for the two positive comments and to the asses keep dreamin hope your ridicule will help you **** out the money some of us actually spend on or cars.
Old Sep 9, 2007 | 06:24 PM
relax, add a gt35r or maybe the hx35 that what's his name is using. You came on and asked what is a damn vague question.."whats the largest and most reliable turbo i should go with" "You say the engine is "built" well none of us are mind readers. What did you do to it? What type of powerrband do you want? Is this going to be a drag strip queen or a daily driver? Most of us assumed you mean 200hp from the turbo..but guess what..there's not a whole lot of maximas period that have that but there are a lot of folks that throw big numbers around without knowing what that really entails. Not to mention that there are actual guru's posting in this thread, as well as people who do spend money on their cars.... You've been on the board for 9 months..that's how long it takes for women to give birth...it's more than long enough to for you to get details on what engine and turbos the 10 most powerful maximas on the board are running, which would give you a great starting point to work with. Anyways that's just my $.02, but i need to cut it short so i can go **** out some money.
Old Sep 9, 2007 | 06:42 PM
Tatanko's Avatar
Bacon Lover
200 WHP can be had fairly easily from an 00VI or DEK...I hope a 3.5 swap is making more than that.
Old Sep 9, 2007 | 08:40 PM
95turbo gxe's Avatar
Hx35 seems to be working well for me
Old Sep 9, 2007 | 11:06 PM
jcy98maxse's Avatar
Turbo is too much fun!
Same for the GT35R for me.
Old Sep 10, 2007 | 12:29 AM
VIP Maxima
relax buddy, why you lose your temper. if you know enough to "build a car" then you should know enough not to ask vauge questions. you spend 10 hours talking about how u want a BIG turbo and then at the end of your reply you mention that you think matty's v1 and s trim would do??? is it just me or there is something wrong with the bottom reply......
matty's kit is a s/c, i thought you wanted to go turbo?
jaydubb's Avatar
62-1. It should feed that VQ30 just fine!
Old Sep 10, 2007 | 05:13 AM
Tatanko's Avatar
Bacon Lover
He's posting that last little bit in reference to absoundlab potentially wanting to buy it *I think*.
Old Sep 10, 2007 | 07:25 AM
Flava_24/7's Avatar
Boosted Panda
Remember guys, this is the same person who was first claiming, and then asking if his SC would make the 520whp.
http://forums.maxima.org/showpost.ph...6&postcount=13
http://forums.maxima.org/showthread.php?t=524915
Im not even sure if he ever even installed the scer but Im assuming he has now realized
it wasnt going to make the 520whp and is now looking to go turboed.
Old Sep 17, 2007 | 09:48 PM
97maximaman's Avatar
Best advise we can all give is to learn to read compressor maps. Google compressor maps and you'll find tons of info on the topic. I honestly dont think you'll get close to 500hp on this engine, not that it cant support it, but its not a big enough engine to start with, and even with a large turbo you'll be getting terrible lag. Boost wont kick in until unreasonably high engine speeds. I'd say the gt35r is as large as i'd go, lots of power and still a nice power band for daily driving.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
