Need parts to rebuild VQDEK (2k1)...
Old Sep 15, 2007 | 07:48 AM
doublea's Avatar
Hey guys, I'm a little bit tired of searching the net, I'm currently rebuilding my VQ30DEK with a lower compression and to also support the abuse of the V2 T trim it will get once everything is put together and the car is ready to hit the road. I have brand new Arias piston, and I'm now in need for the following parts:
1- Head bolts (stronger than oem)
2- Rod bolts & rods (stronger than oem)
3- Complete engine Gasket kit ( the best product available )
4- Valve, spring retainer etc ( both heads are beign ports & polish )
I know many of you will tell me to swap for a VQ35DE, but my project is well on it's way so
swapping is not an option and to be frank I think this engine is going to be much stronger than the VQ35 if I can find the parts I'm missing.
Thanks for your help and feel free to ask me any questions you want.
Cheers
AA
Old Sep 16, 2007 | 05:53 AM
doublea's Avatar
I have a hard time thinking I'm the only one building a VQ30 DEK... I though that I would get a truck load of infos about parts and places to buy but I guess I was plain wrong then...
Old Sep 20, 2007 | 06:57 PM
qnpark8282's Avatar
http://www.importperformanceparts.ne...ssan-rods.html
also valves and springs, you could get from jwt.
Old Sep 20, 2007 | 07:18 PM
NmexMAX's Avatar
dot dot dot ...
What's your CR w/ those pistons?
Old Sep 21, 2007 | 04:43 AM
doublea's Avatar
I believe the compression ratio is 9:1 if not mistaking, I'm building the engine for FI.
Old Sep 21, 2007 | 08:11 AM
NmexMAX's Avatar
dot dot dot ...
I would have never guessed.
If you add VQ35 heads, you will impact the CR. With your pistons, not sure exactly what the actual # will be though.
http://forums.maxima.org/showpost.ph...14&postcount=3
Old Sep 27, 2007 | 10:27 AM
doublea's Avatar
I finally got a PM from an org member who can sell me, spring, retainer, eagle rods and head studs for my VQ30DEK.
Old Sep 27, 2007 | 07:32 PM
QnzMax's Avatar
Would you mind sharing that info? I have a DE-K myself and plan to do some more internals during the winter since the car will be garaged.
Old Sep 28, 2007 | 05:39 AM
doublea's Avatar
I'll send you his info later today, I have to run now.
Cheers
AA
Old Sep 28, 2007 | 07:17 AM
QnzMax's Avatar
Cheers
AA
Thanks buddy.
Old Oct 16, 2007 | 10:54 AM
nwell2k3's Avatar
try atomicspeedware.com and for custom cam regrinds webcamshaft.com
here is a link for a post that i started:
http://forums.nycmaximas.org/showthr...399#post466399
If the link doesn't work here is am email I got from Atomicspeedware.com
ATOMIC SPEEDWARE Sales wrote: Hi- Since we spoke, I verified the VQ30DE valvetrain is the same as the VQ35DE. Here is your quote: Piston kit: ATOMIC custom (forged pistons, pins, rings & locks) - $887 Rods: PAUTER - $1117.50 Head gasket: COMETIC - $84 /ea. Head stud kit: ARP (same as VQ35DE?) - $202.50 Main stud kit: ARP - $178.20 Cams: WEB CAMSHAFTS regrind - $600.00 Valve spring & retainer kit: SUPERTECH - $624 Valves: SUPERTECH - $638.40 Bearings: ACL - $139 Sleeves: DARTON - $1035.00 Add up the required parts and deduct kit discount of 3%. Shipping is additional. Thanks, Nick Arias 3rd ATOMIC SPEEDWARE 805.552.0808 ph 805.529.9783 fx sales@atomicspeedware.com</p>
Old Oct 17, 2007 | 05:47 PM
Nealoc187's Avatar
SLOW
good god you're not actually going to order that stuff are you?
Old Oct 18, 2007 | 07:32 AM
doublea's Avatar
Well I need Rods, Head gasket, Head & Main stud kit, Valve spring, retainer Kit & Valves. I already have the piston & ring. I'll begin to order parts next week.
Old Oct 18, 2007 | 09:03 AM
nismology's Avatar
I would've stayed at stock compression.
Old Oct 19, 2007 | 06:43 AM
doublea's Avatar
I think the 9:5:1 C/R should give me good number with Matty's V1 kit along with a T trim blower & I/C. I'll post some pics soon...
Old Oct 19, 2007 | 11:00 AM
nwell2k3's Avatar
No, I desided to do the DEK swap with head work, webcam turbo regrinds, cometic head gastket and arp studs, etc. The cost was to extreme for just 350WHP...
Old Oct 19, 2007 | 11:08 AM
NmexMAX's Avatar
dot dot dot ...
I think the 9:5:1 C/R ..
Just so you know, it’s 9.5:1
Old Oct 19, 2007 | 11:27 AM
doublea's Avatar
What an additional dot can do... Lol
Old Oct 19, 2007 | 11:29 AM
NmexMAX's Avatar
dot dot dot ...
It's more than a dot. It's a ratio and should be addressed as so.
Old Oct 19, 2007 | 11:33 AM
doublea's Avatar
It was just a dot in my typing. If your in a bad mood just take a deap breath and it will go over time.
Old Oct 19, 2007 | 01:11 PM
Nealoc187's Avatar
SLOW
I agree since you can get 350whp with ease without even touching anything in the motor...
derekinthez
Nov 13, 2022 04:00 PM
MR2 T'd
Jul 9, 2021 05:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
6spd4dsc
Mar 4, 2016 05:19 PM
maximusrising
Sep 2, 2015 09:55 AM
