question about 300zx maf
Old Jan 21, 2008 | 11:13 AM
absoundlab
as you all know I'm turboing my 5th gen vq30de-k. I was going to make a custom inside diameter maf housing and use my factory maf sensor but all the aluminum pipe that I'm finding is 3 inch outside diameter and 2 7/8 inside diameter.
can I use a 300zx (z32) maf sensor on my 5th gen? if so does anyone have a wiring diagram?
Also is there any specific year or model I need to get the maf sensor from?
Do I need a twin turbo 300zx maf?
Old Jan 21, 2008 | 06:11 PM
maxgtr2000's Avatar
KH3 by popular demand
http://forums.maxima.org/showthread....hlight=gen+maf
http://forums.maxima.org/showpost.ph...19&postcount=8 2003-2005 model
I didn't check your build thread to see if you are going to run an emanage, but I was going to say just keep stock maf and use the MAP also.
Old Jan 22, 2008 | 10:26 PM
96blkonblkse's Avatar
Just use the Landrover MAF.
You just swap your Sensor into the LR MAF housing. Its like 82mm i believe.
Old Jan 25, 2008 | 09:57 PM
absoundlab
alright I got a 300zx maf pigtail and maf adapter all I need now is a write up on how to install the 300zx maf in a 5th gen
Old Jan 26, 2008 | 09:14 AM
i30krab's Avatar
Check JWT webpage they may have it or call monday and talk to Ben. If anyone knows it will be them!
Old Feb 2, 2008 | 04:44 AM
sweetdaddygotu's Avatar
hopefully this can shed some light at the end of the tunnel. i found this thread in a local maxima forum!
http://forums.nycmaximas.org/showthread.php?t=18644
Old Feb 10, 2008 | 09:25 AM
ACEMANN's Avatar
FYI 300ZX twin turbo and non-turbo MAF sensors are the same..
Old Feb 11, 2008 | 10:08 AM
I have both a 300zx TT MAF and non-turbo MAF at home. The pins are different (one has 5 pins and the other has 4 pins), and the pig tail wiring colors are different.
Old Feb 11, 2008 | 04:22 PM
ACEMANN's Avatar
http://www.300zx-twinturbo.com/cgi-b...ault&total=190
There are no turbo specific meters - they are the same. They even have the same part number 22680-30P00.
Old Mar 6, 2008 | 06:57 PM
secondtonone317's Avatar
nycnissans
Im also looking into this, some said the z32 maf won't workk with a stock 5th gen ECU....is this true. I have a VAFCII........
Old Mar 7, 2008 | 08:20 AM
Then how do you explain the physical differences I described here???
I'm pretty sure I read in one of absoundlab's posts that he determined that a Z32 MAF couldn't be used. Hopefully he'll chime in here.
Old Mar 7, 2008 | 02:17 PM
NmexMAX's Avatar
dot dot dot ...
It be interesting to see how much the stock sensor can support in THAT housing.
Old Mar 8, 2008 | 09:54 AM
95turbo gxe's Avatar
IIRC one has a extra ground and they do have the same flow propertys!
Old Apr 8, 2008 | 09:19 PM
happy4444's Avatar
didnt seem to find anyone mentioning inner diameter on the 300zx tt/j30 MAF. i read the rover is 82mm but that wont do me any good on my 4th gen. answers appreciated. thanks guys
EDIT.. i found the z32 maf is 72mm. same as oem 4th gen diameter
Old Apr 8, 2008 | 09:27 PM
kzoosho's Avatar
I have a Q45 maf. Its fairly large.
Old Apr 8, 2008 | 10:28 PM
absoundlab
a q45 maf wont work in a 5th gen
Old Apr 8, 2008 | 10:57 PM
kzoosho's Avatar
Well you guys dont have many choices then man.
Old Apr 9, 2008 | 06:39 AM
liqidvenom's Avatar
brotherhood of tq
so is the 300zx maf the only option for us 4th gens?
Old Apr 9, 2008 | 07:54 AM
absoundlab
I've got something in the making right now for all you 5th gen owners out there.
Old Apr 9, 2008 | 08:44 AM
nycnissans
^Happy to be a test dummy
Old Apr 9, 2008 | 09:11 AM
absoundlab
you aren't the test dummy I am lol and its a part that really doesn't need to me tested
Old Apr 9, 2008 | 10:31 AM
kzoosho's Avatar
NO no. I have a q45 maf on my 4th gen man and it works fine. Im barely tapping it.
Old Apr 9, 2008 | 05:58 PM
NmexMAX's Avatar
dot dot dot ...
LRMAF housing will increase the potential for the 5th gen sensor.
Old Apr 10, 2008 | 08:23 AM
nycnissans
^ YES........you are right, hopefully it will help me idle a little smoother too
Old Apr 11, 2008 | 11:08 AM
NmexMAX's Avatar
dot dot dot ...
Odds are it won, LRMAF makes idle quite lean. At least in my experience.
Old Apr 11, 2008 | 12:08 PM
absoundlab
the fix for the 5th gen's will be released soon
Old Apr 12, 2008 | 10:57 AM
NmexMAX's Avatar
dot dot dot ...
ok. . . . .
Old Apr 12, 2008 | 12:59 PM
NewfoundlandDud's Avatar
Subscribed...
Old Apr 13, 2008 | 06:35 PM
happy4444's Avatar
im assuming u have a tune with this as well? how was the improvement. also are you n/a? or fi. thanks
Old Apr 13, 2008 | 06:58 PM
kzoosho's Avatar
Turbo'd and yes i tune with a safcII for now.
Old Apr 22, 2008 | 09:48 AM
absoundlab
custom 3" maf housing
Old Apr 22, 2008 | 09:51 AM
NmexMAX's Avatar
dot dot dot ...
Interesting, though I'm staying NA.
http://forums.maxima.org/showpost.ph...01&postcount=9
Why use reducing couplers? Why not make the entire tract 3"ID?
Old May 13, 2008 | 04:29 AM
nycnissans
^ charge pipe is smaller, the other coupler is a 3in to 3in coupling, its just stretched over the pipe thats why the other side looks smaller. I only know this because I bought one of these from absoundlab before he got banned.
-ReLLiK-
Apr 29, 2016 06:25 PM
BkGreen97
Apr 2, 2016 05:47 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Excalibur23
Oct 13, 2015 04:33 PM
ballerchris510
Sep 10, 2015 09:35 PM
