382whp/380wtq
Old Feb 24, 2010 | 10:26 AM
  #81
Shift_Max's Avatar
Originally Posted by essential1
Like others have said, that locatioin for the oil drain is not the best. (IMO) But others have succesfully ran it there so it shouldnt be a problem. Monitor it though.
There is a flat spot on the upper oil pan towards the front of the car that we used for a 3.5 swaped 4th gen recently. It's working great. I would look into doing that just to be 100% safe.
Guess you missed my point where i brought that up first.
And the location you are talking about is ideal actually. I have my block tapped there for the return.
Old Feb 24, 2010 | 04:38 PM
  #82
Gemner's Avatar
wait, how do i get ahold of one of those exhausts?
Old Feb 25, 2010 | 12:42 PM
  #83
essential1's Avatar
My axles cry for mercy...
My bad.
I didnt catch what they did for the feed line though. Did they use a sandwich plate? Or did they T it off the pressure switch? Is there any other places with our cars we can get oil pressure from?
Old Feb 25, 2010 | 03:35 PM
  #84
digitalbow's Avatar
Not to threadjack, but I can probably answer a few of these questions since I did my own install and my setup is similar.
what is the outlet diameter on the turbo and it is a 2.5 inch downpipe?
If you're asking about the hot side, (and if he's using the same T60-1 as me) the turbine's inlet is mated to a standard T3 (rounded square) flange, which, from his pics, appears to be fed by a 2.5" dia. up pipe. The turbine's discharge is 3" dia. Mine goes to a reducer back down to 2.5" before the flex pipe, but rroderiques77's remains 3" all the way back to the muffler. Free-er flowing, for sure.
Plus personal preference but i would have loved an open dump for the wastegate lol
That would be sick to hear on a Maxima. Or, a boost-activated solenoid that goes to an electric cutout, so it's not deafening all the time.
It's T-d from the pressure sender port. A sandwich plate would be a better idea, especially to run a cooler. You'd probably have to use a shorter filter, though. There's really nowhere else to get oil pressure from (on a stock block).
Another note:
This snail is a good match for a low boost build (<10psi) because it works well with the natural torque characteristics of the VQ to make the car still predictably drivable. A bigger hot side would give you greater top end, but the trim we have yields a very even kick that comes in fully at the lower portion of the mid range. As such, acceleration in the majority of the power band (>4k - redline) is more linear in higher gears than expected from a boosted machine.
Old Feb 25, 2010 | 05:21 PM
  #85
rroderiques77's Avatar
Demodded and Forgotten
Another note:
Couldn't have said any better. Thanks for that!!
Old Feb 28, 2010 | 09:48 AM
  #86
ghostmax301's Avatar
niccce. love the 3" back. sounds too good on maximas..
http://www.youtube.com/BurrTvDotCom1.../1/AhYZB_lRU1g
Old Mar 4, 2010 | 09:35 PM
  #87
aic96max's Avatar
nicely putogether kit. great pics. wish 4th gen could fit the piping the same way. your drain shouldnt be an issue at all. NICE!
Old Jun 27, 2011 | 03:09 AM
  #88
Brl24's Avatar
Wow, that's beauty. I'm in toronto Canada and am hopefully going to be looking for someone to do a similar set up for my 02 mt. Hope it's not to hard to find, anyone know of anybody in my area, that would be great
