JWT Reprogram Options?
Old Mar 13, 2010 | 05:01 PM
C3nthusiast's Avatar
I have a JWT ECU coming that is set up for 550 injectors, 100 octane, and Z32 MAF. I have a stock MAF and 370 injectors. What program options should I ask for when I send it back?
Current Set up:
V1 blower with 3.125 pulley
Vortech FMU with stock disc
370 injectors
Stock MAF
Walboro 255
With the JWT I am going to get rid of the FMU and probably add a FPR.
Old Mar 13, 2010 | 07:57 PM
Flava_24/7's Avatar
Boosted Panda
Current Set up:
370 injectors
Stock MAF
Walboro 255
Why not get a Z32 MAF and ask for the Z32 MAf and 370cc inj program? Also do you have a VI? If so get the extended rev limiter.
Old Mar 14, 2010 | 10:33 AM
Nealoc187's Avatar
SLOW
I wonder what the timing map is on JWT's 100 octane program. I'd like to see a datalog of that.
Old Mar 14, 2010 | 05:49 PM
96sleeper's Avatar
Neal - 18 degrees max advance.
That is probably my old ecu if you bought it from 95stillenmax. It has a 7000rpm redline, and the 550cc injectors are at 3.5 bar fuel pressure, this ecu was setup specifically at 3.5 bar fuel pressure for use with a VQ35. The injectors do not flow 550cc at 3.0 bar fuel pressure. Other than the Z32 MAF, it might run really well on your car cause it was lean with mine. I had to add a bunch of fuel with the SAFC. Do you have a wideband and SAFC or some other tuning device?
Old Mar 15, 2010 | 05:34 PM
Nealoc187's Avatar
SLOW
That's pretty low advance. I'm wracking my memory trying to remember if all JWT reprograms made poor power because of too little advance, or if that was a problem with the 550 and Z32 maf reprogrammed ecus only.
Old Mar 15, 2010 | 05:38 PM
96sleeper's Avatar
Their standard boosted program is like 10 degrees max advance. Its a joke, that is why I requested 100 octane programming, just to get decent timing.
Old Mar 15, 2010 | 05:58 PM
Nealoc187's Avatar
SLOW
OK, yeah that sounds familiar. Ridiculous lol.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Redfox
Sep 28, 2015 10:41 AM
