6spd 6th gen TURBO (Pic Heavy)
4 Attachment(s)
ok so i talked it over with my friends , and my buddy in philly. I decide i wanted to turbo the max. Im not looking for crazy HP numbers, but i rather have the driveability of it. Im only looking to make atleast 350whp.. This is still in the making so stay tuned. enjoy the pictures
BIRDMAN Racingline Strut BAR Attachment 52078 Attachment 52079 Attachment 52080 Attachment 52081 |
4 Attachment(s)
Black intercooler
Attachment 52074 Attachment 52075 Attachment 52076 Black intercooler & New Bumper Attachment 52077 |
3 Attachment(s)
4 Attachment(s)
HKS BOV
Attachment 52067 Holset HX35 ( 8blade, 16cm exhaust housing) Attachment 52068 HX35 vs 57 trim Attachment 52069 Attachment 52070 |
5 Attachment(s)
Battery BOX
Attachment 52062 Walbro 255 Attachment 52063 Gauges & Gauge POD Attachment 52064 Attachment 52065 Attachment 52066 |
4 Attachment(s)
TIAL MVS 38mm Wastegate
Attachment 52058 Attachment 52059 Attachment 52060 OBX G35 /350z oil pan spacer Attachment 52061 |
3 Attachment(s)
4 Attachment(s)
5 Attachment(s)
THE MOCK UP / feedpipe& downpipe build
Attachment 52046 Attachment 52047 Attachment 52048 Attachment 52049 Attachment 52050 |
4 Attachment(s)
Subscribed to this thread. Turbo builds are always fun so enjoy it.
1 Questions though. What psi spring is in the Tial Mv-s wastegate? Also you mentioned that the 600cc injectors are big. In reality they are not since that is what I am using and they are great since they provide a little bit of a safety net. Having them paired up with the Walbro 255lph pump, you will be fine. Also in regards to engine management, I suggest in using Uprev since it is possible to do so on the 6th gen ecu. Much better option then using some kind of air/fuel controller. |
wastegate came with 3 or 4 different springs, i believe 5.8psi, 8.4psi, and a 12psi....
ill most likely be using the 8.4psi as far as tuning options, i got a safc2 and im gonna be using uprev as well. a place in PA called, RT TUNING will be doing this... they specialize in NISSAN's |
+1 for RT Tuning. They are great with Uprev.
Looks fun! All those new parts make me want to spend money but I'm broke...off to buy a happy meal lol...
SWEET!!! Another turbo Maxima around here!!!! We about to join Unklejoe!!!!
Nice looking build. Love seeing new turbo maxis
Nice. Finally some more local turbo Maximas.
Is Tom doing all the piping fab work? And I think you will make more than 350whp on an 8.4 spring. |
i didn't know megan made maxima headers... are they for the 3.5 altimas or how did you find them?
Originally Posted by Unklejoe
(Post 8418731)
Nice build dude.
I am thinking around 375hp and 400+ with the dp open
Originally Posted by ranmas2004
(Post 8418791)
yeah, actually sitting here thinking about it, you should make more than 350whp on 8.4PSI spring. Depends on what dyno. But basically all of them if you ask me....cant wait to see this. Yo, we need to start a TURBO MAXIMA club!!!!
Originally Posted by McSteve
(Post 8418757)
Originally Posted by RAZ76
(Post 8418793)
Nice build dude.
Originally Posted by maximusberg
(Post 8419083)
yes, 8.4 psi im thinking id be about 390whp
(Post 8419157)
I don't know...call me crazy but I think you'll be more than that. I think you'll be past 400whp depending on the tune, but that is possible. Unklejoe made like 374whp on a dyno that reads lower than a dynojet with 7.5PSI. I believe he used stock exhaust manifold. and have a 2.5" exhaust and downpipe I believe. You going in with HEADERS, 3" downpipe and exhaust and ~1 more PSI.....I think you'll be over 400whp. If you dyno on a dynojet you will for sure be over 400whp.
I have one stock manifold in the rear with a custom header in the front. I have a 2.5" downpipe/exhaust with the wastegate dumping to atmosphere. It is important to dump the wastegate to atmosphere if you plan on running a smaller exhaust. My setup still has a LOT of back pressure though. I had to run a 14lb spring in my wastegate just to get it to hold 7psi because the exhaust pressure was actually pushing the wastegate open. This is also probably because the E-Bay wastegate's springs aren't exactly what they say they are; they're a little softer I would imagine. If I could do it all again, I would do a minimum of a 3" down pipe, maybe even a 3.5" with the wastegate re-circulating. And as far as dyno numbers, they can vary from dyno to dyno so it's more useful to just compare to other cars on the same dyno. Also, I'm running 18 degrees of timing with a 11.8 AFR. |
(Post 8419157)
(Post 8420307)
i hope im not 400whp.... id end up blowing my engine, i dont wanna do that
well thats good to know, id hope they tell me too lo l.. uploading pics
4 Attachment(s)
2 inch wastegate pipeAttachment 51930
intercooler / bumper bracketAttachment 51931 turbo/ exhaust housing Attachment 51932 Attachment 51933 |
Holset's are getting popular around here. Looking good. Maybe I can check this out one day. Keep up the good work.
3 Attachment(s)
I'm looking at your pics and it looks like your mocking up the exhaust piping on a vq30 with a 5spd tranny correct me if I'm wrong. I know the 6spd tranny starter is in a different location than the 5spd so you might want to get a 6spd tranny and starter and put it on there
2 Attachment(s)
Originally Posted by TurboA32
(Post 8424615)
Good luck with the build. Looks good so far. :D
Originally Posted by t6378tp
(Post 8425042)
one step ahead of you, got a mock starter to put where a 6spd starter would go. Plus the feed and downpipe will only be tack welded till it test fitted on the car at that point if everything clears then final welding will be done.
4 Attachment(s)
Smart move with using the v-band clamps
3 Attachment(s)
3 Attachment(s)
You have to be careful with the stainless because it tends to crack at the welds
© 2024 MH Sub I, LLC dba Internet Brands
