tread life on tires..
Old Jun 10, 2003 | 09:28 AM
dizmax96's Avatar
anyone know the answer to this question? im thinkin about gettin Yoko AVS ES100 .. does anyone know the tread life on these tires?
Old Jun 10, 2003 | 09:29 AM
Maxima95Tuner
Im getting the Yoko AVS dB, and it's supposed to be really good on tread. Im sure the ES100 will be also.
Old Jun 10, 2003 | 12:58 PM
Max Noob's Avatar
not related to the yokos.but a general tire treaed quesiton.. if i was toeing out..what would my tread wear look like..i think my front pasenger is toeing a lil bit..and my rear allignment seems to be out after the drop..but there are no toe adjustmens in the rear.what do most people do..
Old Jun 10, 2003 | 02:15 PM
DanNY's Avatar
Ad·min·is·tra·tor
if your toe is out then your outside part of the tread would wear more.
you SHOULD have a toe adjustment in the back...camber is another issue.
Old Jun 10, 2003 | 02:20 PM
MaxSE03's Avatar
Tread wear rating is 280......So i would give them about 20-25k. I bought these tires for the wife. They handle great on dry and in the wet. The only thing i don't like about them is the sidewall. They are way to soft for my taste.
Old Jun 10, 2003 | 02:23 PM
Nismo3112's Avatar
Custom User Title
Theoretically, nothing SHOULD change in the rear..its a solid beam exle, the axle is still the same distance from the ground. Just the height between the axle and the body is changed.
Apr 16, 2020 05:15 AM
lrb6805
Sep 24, 2015 05:03 PM
