Need some wheel help...
Old Jun 18, 2003 | 01:29 AM
sanjosemaxima's Avatar
Sleeps with his maxima!
Hey, is a 18x8 wheel with a 45 offset ok for a 4th gen? or would i need wheel spacers?
thanks,
adrian
Old Jun 18, 2003 | 11:31 AM
bump, please help!!
Old Jun 18, 2003 | 12:58 PM
ohannon7's Avatar
are you asking this b/c you think it might rub when you turn the wheel? If so then im not sure. I think the tire size makes a difference too though for example if you have a taller tire it might be closer than a skinny one?
I have 18s w/ 245/40 series and i have pleanty of room w/ a 40 offset.
If it wasnt for that i think it would sit nice inside the wheelwell. give it a more "lowered" look
Old Jun 18, 2003 | 01:24 PM
yes the tires would be 245, is that going to create a problem or will i need wheel spacers?
Old Jun 18, 2003 | 01:55 PM
Lordrandall's Avatar
You will probably need a small spacer.
Old Jun 18, 2003 | 01:56 PM
black5spdmax's Avatar
I have 18x8 45mm offset on my 4th gen and I have no problems
I have 235/40/18 though, you should not have any problems
Old Jun 18, 2003 | 02:52 PM
So what size spacer would be good? 5mm?
Old Jun 18, 2003 | 06:37 PM
If you need a spacer 5mm would be plenty
I do not think that you will require a spacer though
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
