what is offset meam?
Old Jul 14, 2003 | 11:15 AM
spam7788's Avatar
If I'm going to get some after maket rims and it said there is an offset of 35mm. what does that mean?
And is there a web-site I can use to see what size rims and tire will fit my car?
Thx.
Old Jul 14, 2003 | 12:56 PM
kushane's Avatar
Offset refers to the amount (in millimeters) that the hub(?) of the rim is set forward or backward from the true centerline of the wheel.
Basically - the higher the offset number compared to stock, the hub of that wheel set more forward and therefore the wheel will be tucked in more inside the fenders. Conversely , the lower the offset, the more your wheels will stick out. Don't quote me - but the stock offset on Maxima wheels I believe is around 34mm.
Old Jul 14, 2003 | 01:24 PM
drewm's Avatar
Except for the stock offset. At least on the 16in SE rims the offset is 45mm, which is why they looked so tucked in. Most rims look flush on the maxima at between 35-40mm offset.
Old Jul 14, 2003 | 06:41 PM
nice95GLE's Avatar
All rims on the 95-2k3 maximas have a stock offset of 45mm . I don't know about the pre 95 and the 2k4.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
