18x8 32mm offset???
Old Jul 22, 2003 | 07:58 AM
Smokin' X-press's Avatar
18x8 32mm offset???
Would these fit a 2001 Maxima SE. I'm lowered with Eibach and Tokico.
This size also comes in a 38mm offset.
Would these sizes be better or is it better to go w/. 18x8.5 40mm offset.
Please note, I want the wheels to be near the fender, but don't want any rubbing or scraping in the wheel wells or to the fender. i plan on running 235 40 18 tires
Thanks for your help.
Old Jul 22, 2003 | 08:25 AM
kwd2kSE's Avatar
+32 is not enough offset. +38 would work much better with the 18x8. Personal choice on whether the 8 +38 or 8.5 +40 wheels. Both would work with Eibach's. The 8.5's will also work with 245/40 tires. Personally, I've got 18x8.5, +40, and 255/40/18 on order now.
Mike
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
