tires help
tires help
i have 16" 2000 maxima rims original tire size is 215/55/16
i need new tires what tires should i put 215/50/16
215/45/16
215/40/16
i neet to know is is the ride on all of them and what do u recomend me to put thanks
215/45/16
215/40/16
45 and 40 series will be way off and will look like crap.
The 50 series will be closest, but will still be a bit too small. I would get a 225/50/16 if you wanted to go with a different tire size, although I don't know if they recommend a 225 for a 6.5" wide wheel.
Search for "tire calculator" and play around with it.
I know that. I am saying that your stock wheel is 6.5" wide. I don't know if a 225 will work on a 6.5" wheel.
You can't just randomly pick numbers and throw them on your rims. Do you realize how f-d up your car will both look and ride if you get a 40 series tire?
Look here:
http://www.miata.net/garage/tirecalc.html
Look here:
Re: tires help
215/45/16
215/40/16
215/45/16
215/40/16
215/55/16
or
225/50/16
And that's all you can usually fit, unless you want 205s.
