HELP!!! '04 17s on a 99 GXE???
Old Jul 29, 2003 | 11:23 PM
MaXiN99's Avatar
Just bought some '04 17s with 225/55/17 Continental tires on em from ebay and now I can't find any websites that list 225/55 as a possible fit. They are all saying 225/45......Is this going to be a problem?? Anyone experienced with this?
Old Jul 30, 2003 | 12:02 AM
nismos14's Avatar
§è~® f®ÈÄk
uh no it wont be a problem, bc the tires are already on the rims
Old Jul 30, 2003 | 12:19 AM
tdaily2's Avatar
I think he meant a problem fitting them on the car...
and
the only difference in a 45 and 55 is just a little bit of width. The 225/45 is going to be a tad wider than the 225/55... Either should work on the car and the wheels. I assume the 2004s still have a 114.3 or 5-4.5 bolt pattern although I haven't really inquired to that fact. As long as they do you should be fine.
Old Jul 30, 2003 | 12:49 AM
happyricefob's Avatar
V^___^V
and if u need new tires, i suggest the followin 2 sites:
1. The Tire Rack.
2. Discount Tire Co.
Old Jul 30, 2003 | 06:58 AM
nismos14's Avatar
§è~® f®ÈÄk
actually the sidewall would be higher, it wouldnt be wider, necisarrily if they are properly maintained with the proper psi
Old Jul 30, 2003 | 07:22 AM
njmaxseltd's Avatar
Your speedo will be slightly off. It's going to read slightly slower then your actually traveling, maybe 3 -4 MPH off at 60.
tarun900
19
Dec 20, 2021 06:57 PM
jerrod99_se-l
Sep 25, 2015 03:02 AM
Socalstillen
Sep 20, 2015 11:46 PM
JoelP
Sep 19, 2015 01:08 PM
