305/50-15
Old Sep 8, 2003 | 08:23 PM
max83's Avatar
305/50-15
Is there anyway to fit a tire of this size on the front wheels of a 96 Maxima?
Old Sep 9, 2003 | 05:56 AM
MaxDoogie's Avatar
Lemme get this right...You want to fit a 10-11" wide tire on a rim that is meant for a 6.5" tire?
No, you cannot...You may be able to squeeze it on there, but it is in no way safe.
Old Sep 9, 2003 | 06:29 AM
kwd2kSE's Avatar
Typo?? Hope you meant 205/50. If you did, yes they fit.
Old Sep 9, 2003 | 01:39 PM
max83's Avatar
Nope I meant what I typed. I was just wondering if anyone had fit such a wide tire on the front wheels.
Old Sep 9, 2003 | 06:34 PM
drewm's Avatar
Final answer, NO.
You can barely fit 225s, and even that is probably dangerous.
Old Sep 9, 2003 | 08:45 PM
max1ma97se's Avatar
255/35 is the maximum, on a rim that has the right offset, the fluck would u want a suv size tire on a tiny car for?
Old Sep 9, 2003 | 09:22 PM
asu174's Avatar
Clay Aiken has fancy genitals
Are they slicks?
Old Sep 10, 2003 | 06:58 PM
max83's Avatar
drewm: who told you that? BrianV but 255's on
Asu174: yea there Dot slicks
Old Sep 10, 2003 | 08:33 PM
drewm's Avatar
Slicks are different. You never mentioned that.
Check with the manufacturer of the tires for the recommended rim widths to mount it on. 6 inch wide wheels can have at most 225 for most radial tire brands (look for the rim width range, anything else can be dangerous): http://www.tirerack.com/tires/Spec.j...=Potenza+RE950
Old Sep 11, 2003 | 08:40 AM
max83's Avatar
Not really slicks they have a DOT number but thats not important. I know that you can not put a 11 inch tire on a 6 inch rim. I thought you meant that on a Maxima you could not fit any tire wider than 225.
