50mm offset.. will it fit or not?
Old Sep 22, 2003 | 06:01 PM
NYCe MaXiMa's Avatar
which problems may i run into? car is lowered and the wheel would be 7" wide...
Old Sep 23, 2003 | 04:41 PM
maxNYC's Avatar
depends on your tires too. check the offset calc here :
http://forums.maxima.org/showthread.php?t=244080
Old Sep 25, 2003 | 08:10 PM
oops
how the hell did i miss the calculator up top?
does anyone know the offset of the factory 16s on 4th gen SEs?
Old Sep 25, 2003 | 08:48 PM
liquidmax's Avatar
maybe 45's.
Old Sep 26, 2003 | 07:18 AM
DanNY's Avatar
Ad·min·is·tra·tor
IMO 50 is too much. you "might" be able to clear it since it's a 7 inch rim but a 5mm spacer would really help.
for reference on a 8 inch rim at 45 you're almost touching the strut towers..and i mean it's within 1-2 mm clerance. at 7 inch would give it more clearance..but since your offset is at 50 that might take the clearance away.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
