18x8.5 and 38mm offset
Will this size wheel cause any problems or annoyances? Will I have a problem with the center caps as I do not want to put spacers on! I am looking for a wheel that has a nice lip, that is 5 spokes, and this is the only wheel i can find with these dimensions. I dont want to push my luck and was wanting to stay at 18x8. Thanks
Originally Posted by asu174
I have a set. You will be fine, although center cap mounting will depend on the wheel itself.
if you go bigger you might rub in the front on the inner fender well when you turn the wheel all the way. like parking or making a u-turn.
Originally Posted by 97GLES
18x8.5 with a 38mm off-set should use a 235/40/18 tire or smaller.
steveyphat
Sep 15, 2015 03:43 PM
