View Poll Results: Best Rim Width to go for
7.0
0%
7.5
17.65%
8.0 or higher
82.35%
doesnt matter
0%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Best Rim width to get?
Old Nov 20, 2003 | 05:04 PM
meccanoble's Avatar
Sports Button FTW
i see slammed95 going around saying get 8" or wider. What makes 8" so much better than the rest besides larger surface to hold ground? or is that the benefit? Whats the recommended width that u recommend going for?
Old Nov 20, 2003 | 07:42 PM
voltman's Avatar
What size wheel/tire are you running?
235/45/17? 7.5, 8
235/40/18? 8, 8.5
Old Nov 20, 2003 | 09:02 PM
asu174's Avatar
Clay Aiken has fancy genitals
Better handling.... I would never get anything less than 8".
Old Nov 20, 2003 | 10:16 PM
jay23's Avatar
i say go for a 10.5 volk racing TE 37s with a +38 offset
Old Nov 22, 2003 | 04:03 PM
limsandy's Avatar
Did you mention rolling fenders to him?
~limsandy
Old Nov 22, 2003 | 05:41 PM
CullenJ76's Avatar
are you confused?
Old Nov 22, 2003 | 08:57 PM
Juki5536's Avatar
Stick with your lovely 2k+'s and get 235/45/17 ContiExtremeContact
Old Nov 23, 2003 | 05:55 AM
asu174's Avatar
Originally Posted by CullenJ76
are you confused?
Hey, the guy makes less than one post per month. Cut him some slack.
Old Apr 9, 2004 | 03:34 PM
DoGGy
while we are at the subject. i need someone to tell me what each number means when u mention a tire size.
lets say 235/35-19
19 is the radius, is 235 the width of the tire that is in contact with the ground? if so then what is 35?
also whats the difference between 235/35-19 and 245/35-19 ??
Old Apr 9, 2004 | 08:12 PM
DoGGy
thanks alot. so a 245 tire is gonna be in contact with ground more than a 235 by 10 mm, right?
Old Apr 9, 2004 | 10:29 PM
JCmaxse00's Avatar
I'd go with 8.0 or wider personally, because i want more with on tires for better handling.. I have 245/40/19 on a 7.5 wide inch rim only cuz thats the rim i liked and thats as wide as they sold them, if not i would of gotten wider.
Old Apr 10, 2004 | 05:45 AM
soundmike's Avatar
Very sound, Mike
From what i've read on Tirerack, the wheel width also dictates how wide your tire will look.
Something along the lines of, a 245 on a 7.5 will look just as wide as 235 on an 8 (not exact figures but you get the idea)
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
0m3nc0w
Sep 11, 2015 05:21 PM
