My new rims
Old Dec 7, 2003 | 10:38 PM
vsamoylov
My new rims
I finally got my new rims and tires. I have 2k2 rims and Kumho Ecsta 225/50/17 tires. Car handles way better than with 15 inch rims and 215/40/15 tires. No more sounds when cornering hard. Tires are rough thoung compared t my other ones. I love the set up. I will post pics later.
One question though? Will my performes decrease due to my new rims because I heard that 2k2 rims are heavy? I can't feel a difference at all when accelerating. Car accelerates the same and does not feel heavy at all.
Old Dec 7, 2003 | 10:46 PM
NookieMax's Avatar
the rims are heavy, you may not 'feel' the difference that much, but only numbers will tell.
Also the larger wheel diameter (+2 inches) gives you a better gear ratio to the ground.
anybody know what size rims will perform the best on the max?
Old Dec 7, 2003 | 10:51 PM
bombtrack_ratm's Avatar
Straight line is smaller the better. So probably Stock 15's on amazing tires. for handeling, it's larger better, but not too large. 17-19 are probably great with Max's with low profiles.
Old Dec 7, 2003 | 10:52 PM
I would say the best of both worlds are 16's or 17's. above that u are about corners, lower then that, u are about speed.
Old Dec 7, 2003 | 10:54 PM
RastaManMax's Avatar
You should feel the difference... On and off the track... You went from ~16.5lb wheels to ~24+lb wheels and went up in overall diameter as well... Just a quick Q, why were you running 40 series sidewalls on your 15" wheels? Into racing?
LEMAR
Old Dec 7, 2003 | 10:57 PM
vsamoylov
There is that big of a difference. I got to weigh my tires somehow?
And yes I am into racing but I try to do it safely and not recklessly. And that tire size is normal 215/40/15.
Old Dec 7, 2003 | 11:21 PM
drewm's Avatar
Actually normal is 205/65/15. 40 series is what I run on 18s and they are tiny.
Old Dec 7, 2003 | 11:51 PM
happyricefob's Avatar
V^___^V
did you get ecsta 711 or 712?
my stock GXE rim/tire weight 39lbs each, my voxx MGR/ecsta supra weights 46lbs. so that means i went up +7lbs each side, so +24lbs all four corners.
not too bad, ecsta supra gives quality grip, and hugs well around the corner. very nice tire for $80/piece.
Old Dec 8, 2003 | 06:20 AM
Kashoggio's Avatar
yeah man if 15 looked good i would roll on them all the time... heavy rims suck.
Old Dec 8, 2003 | 10:19 AM
vsamoylov
I check and tell you what they are.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
