Can I mount 215/50-15 tires on the 96 factory 15? sawblade wheel?
Old Dec 10, 2003 | 11:22 PM
sickmen's Avatar
Well, my tires are bald and I need to change it.
However, I don't like the thik sidewall of the factory tires and I would like to have low profile tires, somewhat like 215/50-15.
The factory tires are 215/60-15 so I think I could mount 215/50-15 tires on a set of factory 96SE sawblade wheels without any problem, right?
Also, is it possible to mount 225/50-15 or something like that on factory 15" wheel? I just want something more sportier looking tires but can?t afford any new set of wheels.
Please let me know! Thanks!
P.S. I live in Atlanta and is it ok to mount summer tires through out the year? We only see snow maybe once a year and I don?t drive when it?s snowing. Please let me know this as well.
Old Dec 11, 2003 | 01:40 AM
happyricefob's Avatar
V^___^V
american co. tire or tirerack should be able to complete the task for you no problem.
and yes it will fit.
Old Dec 11, 2003 | 04:48 AM
Jatan's Avatar
http://forums.maxima.org/showthread.php?t=243784
Old Dec 11, 2003 | 05:15 AM
sickmen's Avatar
Thanks for your reply guys?
Somehow I couldn?t used the search function anymore.
Anyways, so I could use either 225/50-15 or 215/50-15 on factory 15? sawblade wheels with no problem?
Any safety concern when using this tires on stock wheel?
I just don?t want my wheels to come off while I?m driving.
Thanks again
Old Dec 11, 2003 | 06:33 AM
MikeD95SE's Avatar
Thanks again
Not sure if you have a drop or anything but I think you will have an even worse wheel gap if you put smaller tires on these wheels but I might be wrong. Just something to think about.
Mike
Old Dec 11, 2003 | 02:09 PM
Jatan's Avatar
They will fit, but if you look at the link I posted above, your speedometer will be faster than the actual speed. According to the site:
215/50/15
"Speedometer reading with non-stock tire is 6.7% too fast.
When your speedo reads 60mph, you are actually traveling 56mph"
225/50/15
"Speedometer reading with non-stock tire is 8.4% too fast.
When your speedo reads 60mph, you are actually traveling 54.9mph"
Old Dec 11, 2003 | 03:01 PM
asu174's Avatar
Clay Aiken has fancy genitals
It will definitely accentuate the wheel gap if you have stock suspension.
Old Dec 11, 2003 | 05:11 PM
sickmen's Avatar
haha... ok. I think I'm going to have 225/60-15. this is OK right as far as safety and wheel gap?
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 21, 2015 01:38 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
